[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-99-g1b24b38
Fri Feb 19 10:07:53 PST 2021
the project "PostGIS".
       via  1b24b38a0d1bd7c1b34af27871505784291e6952 (commit)
      from  a39944c37f1b1b6efa3e90c6f51f1d9f016d4f53 (commit)
revisions in full, below.
commit 1b24b38a0d1bd7c1b34af27871505784291e6952
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Fri Feb 19 10:09:40 2021 -0800
    Change docs to use ST_Point where possible
diff --git a/doc/reference_operator.xml b/doc/reference_operator.xml
index 26c7166..eb248ad 100644
--- a/doc/reference_operator.xml
+++ b/doc/reference_operator.xml
@@ -141,7 +141,7 @@ FROM ( VALUES
 		  <refsection>
 			<title>Examples</title>
-			<programlisting>SELECT ST_MakePoint(1,1) && ST_MakeBox2D(ST_MakePoint(0,0), ST_MakePoint(2,2)) AS overlaps;
+			<programlisting>SELECT ST_Point(1,1) && ST_MakeBox2D(ST_Point(0,0), ST_Point(2,2)) AS overlaps;
  overlaps
@@ -207,7 +207,7 @@ FROM ( VALUES
 		  <refsection>
-			<programlisting>SELECT ST_MakeBox2D(ST_MakePoint(0,0), ST_MakePoint(2,2)) && ST_MakePoint(1,1) AS overlaps;
+			<programlisting>SELECT ST_MakeBox2D(ST_Point(0,0), ST_Point(2,2)) && ST_Point(1,1) AS overlaps;
  overlaps
@@ -273,7 +273,7 @@ FROM ( VALUES
 		  <refsection>
-			<programlisting>SELECT ST_MakeBox2D(ST_MakePoint(0,0), ST_MakePoint(2,2)) && ST_MakeBox2D(ST_MakePoint(1,1), ST_MakePoint(3,3)) AS overlaps;
+			<programlisting>SELECT ST_MakeBox2D(ST_Point(0,0), ST_Point(2,2)) && ST_MakeBox2D(ST_Point(1,1), ST_Point(3,3)) AS overlaps;
  overlaps
@@ -1223,7 +1223,7 @@ FROM
 		  <refsection>
-			<programlisting>SELECT ST_Buffer(ST_GeomFromText('POINT(2 2)'), 1) @ ST_MakeBox2D(ST_MakePoint(0,0), ST_MakePoint(5,5)) AS is_contained;
+			<programlisting>SELECT ST_Buffer(ST_GeomFromText('POINT(2 2)'), 1) @ ST_MakeBox2D(ST_Point(0,0), ST_Point(5,5)) AS is_contained;
  is_contained
@@ -1289,7 +1289,7 @@ FROM
 		  <refsection>
-			<programlisting>SELECT ST_MakeBox2D(ST_MakePoint(2,2), ST_MakePoint(3,3)) @ ST_Buffer(ST_GeomFromText('POINT(1 1)'), 10) AS is_contained;
+			<programlisting>SELECT ST_MakeBox2D(ST_Point(2,2), ST_Point(3,3)) @ ST_Buffer(ST_GeomFromText('POINT(1 1)'), 10) AS is_contained;
  is_contained
@@ -1355,7 +1355,7 @@ FROM
 		  <refsection>
-			<programlisting>SELECT ST_MakeBox2D(ST_MakePoint(2,2), ST_MakePoint(3,3)) @ ST_MakeBox2D(ST_MakePoint(0,0), ST_MakePoint(5,5)) AS is_contained;
+			<programlisting>SELECT ST_MakeBox2D(ST_Point(2,2), ST_Point(3,3)) @ ST_MakeBox2D(ST_Point(0,0), ST_Point(5,5)) AS is_contained;
  is_contained
@@ -1627,7 +1627,7 @@ FROM
 		  <refsection>
-			<programlisting>SELECT ST_Buffer(ST_GeomFromText('POINT(1 1)'), 10) ~ ST_MakeBox2D(ST_MakePoint(0,0), ST_MakePoint(2,2)) AS contains;
+			<programlisting>SELECT ST_Buffer(ST_GeomFromText('POINT(1 1)'), 10) ~ ST_MakeBox2D(ST_Point(0,0), ST_Point(2,2)) AS contains;
  contains
@@ -1693,7 +1693,7 @@ FROM
 		  <refsection>
-			<programlisting>SELECT ST_MakeBox2D(ST_MakePoint(0,0), ST_MakePoint(5,5)) ~ ST_Buffer(ST_GeomFromText('POINT(2 2)'), 1) AS contains;
+			<programlisting>SELECT ST_MakeBox2D(ST_Point(0,0), ST_Point(5,5)) ~ ST_Buffer(ST_GeomFromText('POINT(2 2)'), 1) AS contains;
  contains
@@ -1759,7 +1759,7 @@ FROM
 		  <refsection>
-			<programlisting>SELECT ST_MakeBox2D(ST_MakePoint(0,0), ST_MakePoint(5,5)) ~ ST_MakeBox2D(ST_MakePoint(2,2), ST_MakePoint(3,3)) AS contains;
+			<programlisting>SELECT ST_MakeBox2D(ST_Point(0,0), ST_Point(5,5)) ~ ST_MakeBox2D(ST_Point(2,2), ST_Point(3,3)) AS contains;
  contains
Summary of changes:
 doc/reference_operator.xml | 18 +++++++++---------
 1 file changed, 9 insertions(+), 9 deletions(-)
hooks/post-receive
