[postgis-tickets] [PostGIS] #4860: Fails to build with PROJ 8.0.0
trac at osgeo.org
Sun Feb 21 08:13:42 PST 2021
Reporter: Bas Couwenberg | Owner: strk
Type: defect | Status: new
Priority: high | Milestone: PostGIS 3.1.2
Component: build/upgrade/install | Version: 3.1.x
Keywords: |
postgis fails to build with PROJ 8.0.0:
checking for PROJ... yes
checking proj_api.h usability... no
checking proj_api.h presence... no
checking for proj_api.h... no
checking proj.h usability... yes
checking proj.h presence... yes
checking for proj.h... yes
checking for proj.h... (cached) yes
checking for pj_get_release in -lproj... no
configure: error: could not find libproj - you may need to specify the
directory of a PROJ installation using --with-projdir
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4860>
