[postgis-tickets] [PostGIS] #4860: Fails to build with PROJ 8.0.0
trac at osgeo.org
Mon Feb 22 11:31:45 PST 2021
Reporter: Bas Couwenberg | Owner: strk
Type: defect | Status: new
Priority: high | Milestone: PostGIS 3.1.2
Component: build/upgrade/install | Version: 3.1.x
Resolution: | Keywords:
Comment (by Bas Couwenberg):
The attached patch fixes the issue for me, it uses `AC_CHECK_LIB` with
`proj_info` (which is available in `proj.h`) as a second opinion when
`AC_CHECK_LIB` with `pj_get_release` (which was in `proj_api.h`) fails.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4860#comment:1>
