[postgis-tickets] [SCM] PostGIS branch stable-2.5 updated. 2.5.5-8-ge9b9d34
git at osgeo.org
git at osgeo.org
Fri Feb 26 11:57:55 PST 2021
the project "PostGIS".
The branch, stable-2.5 has been updated
via e9b9d34339515882ae4927ead8e44539438950e6 (commit)
via 3cc50059baecf6165ad63d7ff4175f9a211a5aa0 (commit)
via 9826b5cc3cf5e475b1f95b5bd176345030b3a52d (commit)
from 279df533083aaa5d8926bbdfb55a5fd43fefa1ea (commit)
revisions in full, below.
commit e9b9d34339515882ae4927ead8e44539438950e6
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Feb 26 10:36:44 2021 -0800
Ensure bboxes are refreshed after cooridinate transforms in scale/affine. References #4863
diff --git a/NEWS b/NEWS
index d3fec34..18ddb5f 100644
--- a/NEWS
+++ b/NEWS
@@ -5,6 +5,8 @@ YYYY/MM/DD
- #4757, Handle line collapse due to snap-to-existing node (Sandro Santilli)
- #4769, Fix segfault in st_addband (Raúl Marín)
+ - #4863, Update bboxes after affine/scale operations (Paul Ramsey)
PostGIS 2.5.5
2020/08/15
diff --git a/liblwgeom/lwgeom.c b/liblwgeom/lwgeom.c
index 12873ed..896af66 100644
--- a/liblwgeom/lwgeom.c
+++ b/liblwgeom/lwgeom.c
@@ -2029,6 +2029,9 @@ lwgeom_affine(LWGEOM *geom, const AFFINE *affine)
+ /* Recompute bbox if needed */
+ if (geom->bbox)
+ lwgeom_refresh_bbox(geom);
void
@@ -2081,19 +2084,8 @@ lwgeom_scale(LWGEOM *geom, const POINT4D *factor)
- if ( geom->bbox )
- /* TODO: expose a gbox_scale function */
- geom->bbox->xmin *= factor->x;
- geom->bbox->xmax *= factor->x;
- geom->bbox->ymin *= factor->y;
- geom->bbox->ymax *= factor->y;
- geom->bbox->zmin *= factor->z;
- geom->bbox->zmax *= factor->z;
- geom->bbox->mmin *= factor->m;
- geom->bbox->mmax *= factor->m;
+ if (geom->bbox)
LWGEOM*
diff --git a/regress/tickets.sql b/regress/tickets.sql
index f5addc4..3d7c701 100644
--- a/regress/tickets.sql
+++ b/regress/tickets.sql
@@ -1125,4 +1125,11 @@ SELECT '#4670-1', ST_AsEWKT(ST_AddPoint('LINESTRING(0 0, 1 1, 3 3, 4 4)'::geomet
SELECT '#4670-2', ST_AsEWKT(ST_AddPoint('LINESTRING(0 0, 1 1, 3 3, 4 4)'::geometry, 'POINT(2 2)'::geometry, 2));
SELECT '#4670-3', ST_AsEWKT(ST_AddPoint('LINESTRING(0 0, 1 1, 3 3, 4 4)'::geometry, 'POINT(2 2)'::geometry, 3));
SELECT '#4670-4', ST_AsEWKT(ST_AddPoint('LINESTRING(0 0, 1 1, 3 3, 4 4)'::geometry, 'POINT(2 2)'::geometry, 4));
-SELECT '#4670-5', ST_AsEWKT(ST_AddPoint('LINESTRING(0 0, 1 1, 3 3, 4 4)'::geometry, 'POINT(2 2)'::geometry, 5));
\ No newline at end of file
+SELECT '#4670-5', ST_AsEWKT(ST_AddPoint('LINESTRING(0 0, 1 1, 3 3, 4 4)'::geometry, 'POINT(2 2)'::geometry, 5));
+SELECT '#4863', st_contains(geometry, st_scale(st_orientedenvelope(geometry),
+ 'SRID=3857; POINT(0.8 0.8)', st_centroid(geometry))) from (select
+ 'SRID=3857; POLYGON((-141972.789895508 6755731.24770785,-141935.49511986
+ 6755733.56891884,-141934.403428904 6755716.1146343,-141971.698204552
+ 6755713.77835553,-141972.789895508 6755731.24770785))'::geometry as
+ geometry) x;
diff --git a/regress/tickets_expected b/regress/tickets_expected
index cf76f6f..96372d5 100644
--- a/regress/tickets_expected
+++ b/regress/tickets_expected
@@ -345,3 +345,4 @@ NOTICE: table "bug_4144_table" does not exist, skipping
#4670-3|LINESTRING(0 0,1 1,3 3,2 2,4 4)
#4670-4|LINESTRING(0 0,1 1,3 3,4 4,2 2)
ERROR: LWGEOM_addpoint: Invalid offset
+#4863|t
commit 3cc50059baecf6165ad63d7ff4175f9a211a5aa0
Merge: 9826b5c 279df53
Date: Fri Feb 26 11:53:44 2021 -0800
Merge branch 'stable-2.5' of https://git.osgeo.org/gitea/postgis/postgis into stable-2.5
commit 9826b5cc3cf5e475b1f95b5bd176345030b3a52d
Date: Thu Nov 5 14:45:55 2020 -0800
Long-standing bug in pole adjustment code for bounding boxes.
Results in incorrect box for shapes wrapping the negative Y geocentric axis (-90,0)
Closes #4727
index 9586eee..fda3804 100644
--- a/NEWS
+++ b/NEWS
@@ -13,6 +13,7 @@ PostGIS 2.5.5
- #4691, Fix segfault during gist index creation with empty geometries (Raúl Marín)
- #4541, ST_ConcaveHull returns a "geometrycollection"
type instead of the expected "polygon" (Regina Obe)
+ - #4727, Fix geocentric bounding box computation for rare case (Paul Ramsey)
PostGIS 2.5.4
2020/02/28
diff --git a/liblwgeom/lwgeodetic.c b/liblwgeom/lwgeodetic.c
index c5dfb8b..85ab13f 100644
--- a/liblwgeom/lwgeodetic.c
+++ b/liblwgeom/lwgeodetic.c
@@ -360,7 +360,7 @@ static int gbox_check_poles(GBOX *gbox)
else if ((gbox->ymin < 0.0) && (gbox->ymax < 0.0))
LWDEBUG(4, "enclosed negative y axis");
- gbox->ymax = -1.0;
+ gbox->ymin = -1.0;
else
Summary of changes:
NEWS | 3 +++
liblwgeom/lwgeodetic.c | 2 +-
liblwgeom/lwgeom.c | 18 +++++-------------
regress/tickets.sql | 9 ++++++++-
regress/tickets_expected | 1 +
5 files changed, 18 insertions(+), 15 deletions(-)
hooks/post-receive
