[postgis-tickets] [PostGIS] #4825: Memory Leak with ST_MakeValid() and invalid geometry?
trac at osgeo.org
Tue Jan 5 06:06:54 PST 2021
Reporter: neumann | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.1
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by neumann):
ok - so it may not be a memory leak then. Good.
The problem I have is that geometries that had been detected as invalid
later get labeled as valid in subsequent runs. See
https://www.carto.net/neumann/temp/st_make_valid_mem_problems.mp4 where
you see that there are fewer and fewer lines in the result set, until at
the end there is only one record labeled as invalid.
I would expect that the "SELECT" statement in this ticket would always
result in the same record set when running with the same data.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4825#comment:8>
