[postgis-tickets] [PostGIS] #4922: Axis order wrong in PostGIS 3.1.2 (may relates to #4842)
trac at osgeo.org
Tue Jun 8 01:48:58 PDT 2021
Reporter: tjay | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.3
Component: postgis | Version: 3.1.x
Resolution: | Keywords:
Comment (by fnadler):
I suspect this behaviour is introducted by #4842, which states, that in
case first column does not include "Lat", the EPSG database order is
chosen.
In case of EPSG 31466, proj's internal database (sqlite) output the
following order:
select axis.name, coordinate_system_order
from projected_crs
inner join axis on projected_crs.coordinate_system_code =
axis.coordinate_system_code
where projected_crs.code = 31466
order by coordinate_system_order
Northing
Easting
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4922#comment:3>
