[postgis-tickets] [SCM] PostGIS branch stable-3.0 updated. 3.0.3-15-g0091177
git at osgeo.org
git at osgeo.org
Mon Mar 1 13:40:37 PST 2021
the project "PostGIS".
The branch, stable-3.0 has been updated
via 0091177ea6801e75ce0ac0f7b1487e8ee711f95e (commit)
from 9ef629f7d8c8c1b34a210d6f5ec8173cfb2af7b0 (commit)
revisions in full, below.
commit 0091177ea6801e75ce0ac0f7b1487e8ee711f95e
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Mar 1 13:38:47 2021 -0800
Address differing error messages from Proj 8 and <8. References #4860
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index ce2af9d..267adfd 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -591,7 +591,30 @@ select '#1578', st_within(p, mp), st_intersects(p, mp) FROM inp;
-- #1580
select '#1580.1', ST_Summary(ST_Transform('SRID=4326;POINT(0 0)'::geometry, 3395));
-select '#1580.2', ST_Transform('SRID=4326;POINT(180 95)'::geometry, 3395); -- fails
+do $$
+declare
+proj_version integer;
+err_str text;
+begin
+ select ((regexp_matches(postgis_proj_version(), '(\d+)\.\d+'))[1])::integer into proj_version;
+ select ST_Transform('SRID=4326;POINT(180 95)'::geometry, 3395); -- fails
+exception
+when others then
+ err_str := SQLERRM;
+ if proj_version >= 8 and SQLERRM = 'transform: Invalid coordinate (2049)' then
+ raise notice '#1580.2: Caught a PROJ error';
+ elsif proj_version < 8 and SQLERRM = 'transform: latitude or longitude exceeded limits (-14)' then
+ else
+ raise notice '#1580.2: Unexpected PROJ Result. Proj version = %. Error string: %', proj_version, err_str;
+ end if;
+end;
+$$ language 'plpgsql';
select '#1580.3', ST_Summary(ST_Transform('SRID=4326;POINT(0 0)'::geometry, 3395));
-- #1596 --
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index ec6c0e5..f3ff300 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -195,7 +195,7 @@ ERROR: got NULL for SRID (500001)
#1543|MULTILINESTRING((0 0,10 0,10 10,0 0),(0 0))|POLYGON((0 0,10 10,10 0,0 0))
#1578|f|f
#1580.1|Point[S]
-ERROR: transform: latitude or longitude exceeded limits (-14)
+NOTICE: #1580.2: Caught a PROJ error
#1580.3|Point[S]
#1596.1|public.road_pg.roads_geom SRID:3395 TYPE:POINT DIMS:2
ERROR: invalid SRID: 330000 not found in spatial_ref_sys
Summary of changes:
regress/core/tickets.sql | 25 ++++++++++++++++++++++++-
regress/core/tickets_expected | 2 +-
2 files changed, 25 insertions(+), 2 deletions(-)
hooks/post-receive
