[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-106-g5cefc43
    git at osgeo.org
    git at osgeo.org
    Tue Mar  2 08:10:40 PST 2021
the project "PostGIS".
       via  5cefc43ae4a7af6def49cbba0fd8f5f8eb556585 (commit)
      from  24c1edea5e8f56c415338afec6139f7f5bd6c121 (commit)
revisions in full, below.
commit 5cefc43ae4a7af6def49cbba0fd8f5f8eb556585
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Mar 2 17:08:58 2021 +0100
    Add run_test.pl hook switches
    Adds the following switches to run_test.pl:
      --after-create-script <path>
      --before-uninstall-script <path>
      --before-upgrade-script <path>
      --after-upgrade-script <path>
diff --git a/regress/run_test.pl b/regress/run_test.pl
index d018ecd..aae3d0e 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -66,6 +66,10 @@ my $OPT_WITH_RASTER = 0;
 my $OPT_WITH_SFCGAL = 0;
 my $OPT_EXPECT = 0;
 my $OPT_EXTENSIONS = 0;
+my $OPT_HOOK_AFTER_CREATE = '';
+my $OPT_HOOK_BEFORE_UNINSTALL = '';
+my $OPT_HOOK_BEFORE_UPGRADE = '';
+my $OPT_HOOK_AFTER_UPGRADE = '';
 my $OPT_EXTVERSION = '';
 my $OPT_UPGRADE_PATH = '';
 our $OPT_UPGRADE_FROM = '';
@@ -86,7 +90,11 @@ GetOptions (
 	'sfcgal' => \$OPT_WITH_SFCGAL,
 	'expect' => \$OPT_EXPECT,
 	'extensions' => \$OPT_EXTENSIONS,
-	'schema=s' => \$OPT_SCHEMA
+	'schema=s' => \$OPT_SCHEMA,
+	'after-create-script=s' => \$OPT_HOOK_AFTER_CREATE,
+	'before-uninstall-script=s' => \$OPT_HOOK_BEFORE_UNINSTALL,
+	'before-upgrade-script=s' => \$OPT_HOOK_BEFORE_UPGRADE,
+	'after-upgrade-script=s' => \$OPT_HOOK_BEFORE_UPGRADE
 if ( @ARGV < 1 )
@@ -291,7 +299,8 @@ sub semver_lessthan
 sub create_upgrade_test_objects
-  # TODO: allow passing the "upgrade-init" script via commandline
+  # TODO: replace the following with --before-upgrade-script usage
   my $query = "create table upgrade_test(g1 geometry, g2 geography";
   $query .= ", r raster" if ( $OPT_WITH_RASTER );
@@ -398,7 +407,13 @@ sub drop_upgrade_test_objects
 if ( $OPT_UPGRADE )
-	print "  Upgrading from postgis $libver\n";
+	print "Upgrading from postgis $libver\n";
+	if ( '' ne $OPT_HOOK_BEFORE_UPGRADE )
+		print "Running before-upgrade-script $OPT_HOOK_BEFORE_UPGRADE\n";
+		die unless load_sql_file($OPT_HOOK_BEFORE_UPGRADE, 1);
   create_upgrade_test_objects();
@@ -413,6 +428,12 @@ if ( $OPT_UPGRADE )
   drop_upgrade_test_objects();
+	if ( '' ne $OPT_HOOK_AFTER_UPGRADE )
+		print "  Running after-upgrade-script $OPT_HOOK_AFTER_UPGRADE\n";
+		die unless load_sql_file($OPT_HOOK_AFTER_UPGRADE, 1);
   # Update libver
   $libver = sql("select postgis_lib_version()");
@@ -465,6 +486,14 @@ our $TEST = "";
 print "\nRunning tests\n\n";
+if ( '' ne $OPT_HOOK_AFTER_CREATE )
+	start_test("after-create-script");
+	show_progress();
+	pass("($OPT_HOOK_AFTER_CREATE)")
+		if load_sql_file($OPT_HOOK_AFTER_CREATE, 1);
 foreach $TEST (@ARGV)
 	my $TEST_OBJ_COUNT_PRE;
@@ -545,6 +574,14 @@ foreach $TEST (@ARGV)
+if ( '' ne $OPT_HOOK_BEFORE_UNINSTALL )
+	start_test("before-uninstall-script");
+	show_progress();
+	pass("($OPT_HOOK_BEFORE_UNINSTALL)")
+		if load_sql_file($OPT_HOOK_BEFORE_UNINSTALL, 1);
 # Uninstall postgis (serves as an uninstall test)
@@ -619,6 +656,14 @@ Options:
   --clean         cleanup test logs on exit
   --expect        save obtained output as expected
   --extension     load using extensions
+  --after-create-script <path>
+									script to load after spatial db creation
+  --before-uninstall-script <path>
+									script to load before spatial extension uninstall
+  --before-upgrade-script <path>
+									script to load before upgrade
+  --after-upgrade-script <path>
+									script to load after upgrade
@@ -1363,7 +1408,8 @@ sub load_sql_file
 	if ( $strict && ! -e $file )
-		die "Unable to find $file\n";
+		fail "Unable to find $file";
+		return 0;
 	if ( -e $file )
@@ -1378,7 +1424,8 @@ sub load_sql_file
 		if ( $rv )
 		  fail "Error encountered loading $file", $REGRESS_LOG;
-		  exit 1;
+		  #exit 1;
+			return 0;
 	return 1;
@@ -1850,6 +1897,7 @@ sub drop_spatial_extensions
 sub uninstall_spatial
 	my $ok;
 	start_test("uninstall");
 	if ( $OPT_EXTENSIONS )
@@ -1861,24 +1909,19 @@ sub uninstall_spatial
 		$ok = drop_spatial();
-	if ( $ok )
-		show_progress(); # on to objects count
-		$OBJ_COUNT_POST = count_db_objects();
+	return $ok if ! $ok;
-		if ( $OBJ_COUNT_POST != $OBJ_COUNT_PRE )
-			fail("Object count pre-install ($OBJ_COUNT_PRE) != post-uninstall ($OBJ_COUNT_POST)");
-			return 0;
-		else
-			pass("($OBJ_COUNT_PRE)");
-			return 1;
+	show_progress(); # on to objects count
+	$OBJ_COUNT_POST = count_db_objects();
+	if ( $OBJ_COUNT_POST != $OBJ_COUNT_PRE )
+		fail("Object count pre-install ($OBJ_COUNT_PRE) != post-uninstall ($OBJ_COUNT_POST)");
+		return 0;
-	return 0;
+	pass("($OBJ_COUNT_PRE)");
+	return 1;
 # Dump and restore the database
Summary of changes:
 regress/run_test.pl | 83 ++++++++++++++++++++++++++++++++++++++++-------------
 1 file changed, 63 insertions(+), 20 deletions(-)
hooks/post-receive
