[postgis-tickets] [PostGIS] #4866: test_lwgeom_make_valid failing on winnie
PostGIS trac at osgeo.org
Tue Mar 2 12:18:33 PST 2021
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  blocker    |  Milestone:  PostGIS 3.2.0
Component:  buildbots  |    Version:  master
 Keywords:             |
 I think this might only be an issue on winnie, and most likely has to do
 with GEOS changes.
 I'm guessing this started happening around Feb 15th or 16th or so
 unfortunately I have the logs delete if past 10 days and I haven't been
 paying close attention.
 Says GEOS 3.9.1dev (why the freak is this still 3.9.1dev is geos 3.9.1
 branch not flipped to 3.9.2dev)
  -------------- Dependencies --------------
   GEOS config:          /projects/geos/rel-3.9w64gcc81/bin/geos-config
   GEOS version:         3.9.1dev
   GDAL config:          /projects/gdal/rel-3.2.1w64gcc81/bin/gdal-config
   GDAL version:         3.2.1
   SFCGAL config:        /projects/CGAL/rel-sfcgal-1.3.9w64gcc81/bin
 /sfcgal-config
   SFCGAL version:       1.3.8
   PostgreSQL config:
 /projects/postgresql/rel/pg11w64gcc81/bin/pg_config
   PostgreSQL version:   PostgreSQL 11.2
   PROJ4 version:        71
   Libxml2 config:       /projects/libxml/rel-
 libxml2-2.9.9w64gcc81/bin/xml2-config
   Libxml2 version:      2.9.9
   JSON-C support:       yes
   protobuf support:     yes
   protobuf-c version:   1002001
   PCRE support:         yes
   Perl:                 /usr/bin/perl
 Suite: buildarea
   Test: buildarea1 ...passed
   Test: buildarea2 ...passed
   Test: buildarea3 ...passed
   Test: buildarea4 ...passed
   Test: buildarea4b ...passed
   Test: buildarea5 ...passed
   Test: buildarea6 ...passed
   Test: buildarea7 ...passed
 Suite: geometry_clean
   Test: test_lwgeom_make_valid ...passed
 Suite: clip_by_rectangle
   Test: test_lwgeom_clip_by_rect ...DEBUG1: lwgeom_clip_by_rect: GEOS
 Error: IllegalArgumentException: Invalid number of points in LinearRing
 found 3 - must be 0 or >= 4
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4866>
