[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-110-g4bc6b1e
git at osgeo.org
git at osgeo.org
Thu Mar 4 01:06:58 PST 2021
the project "PostGIS".
via 4bc6b1ee11e1bb7df3786d904ab04fe816fc08ec (commit)
from 289bb4842d039b7ed6abc7180d2208c0a9ef474c (commit)
revisions in full, below.
commit 4bc6b1ee11e1bb7df3786d904ab04fe816fc08ec
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Mar 4 10:03:21 2021 +0100
Accept multiple hook scripts
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 6107915..72b254e 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -66,10 +66,10 @@ my $OPT_WITH_RASTER = 0;
my $OPT_WITH_SFCGAL = 0;
my $OPT_EXPECT = 0;
my $OPT_EXTENSIONS = 0;
-my $OPT_HOOK_AFTER_CREATE = '';
-my $OPT_HOOK_BEFORE_UNINSTALL = '';
-my $OPT_HOOK_BEFORE_UPGRADE = '';
-my $OPT_HOOK_AFTER_UPGRADE = '';
+my @OPT_HOOK_AFTER_CREATE;
+my @OPT_HOOK_BEFORE_UNINSTALL;
+my @OPT_HOOK_BEFORE_UPGRADE;
+my @OPT_HOOK_AFTER_UPGRADE;
my $OPT_EXTVERSION = '';
my $OPT_UPGRADE_PATH = '';
our $OPT_UPGRADE_FROM = '';
@@ -91,10 +91,10 @@ GetOptions (
'expect' => \$OPT_EXPECT,
'extensions' => \$OPT_EXTENSIONS,
'schema=s' => \$OPT_SCHEMA,
- 'after-create-script=s' => \$OPT_HOOK_AFTER_CREATE,
- 'before-uninstall-script=s' => \$OPT_HOOK_BEFORE_UNINSTALL,
- 'before-upgrade-script=s' => \$OPT_HOOK_BEFORE_UPGRADE,
- 'after-upgrade-script=s' => \$OPT_HOOK_BEFORE_UPGRADE
+ 'after-create-script=s' => \@OPT_HOOK_AFTER_CREATE,
+ 'before-uninstall-script=s' => \@OPT_HOOK_BEFORE_UNINSTALL,
+ 'before-upgrade-script=s' => \@OPT_HOOK_BEFORE_UPGRADE,
+ 'after-upgrade-script=s' => \@OPT_HOOK_BEFORE_UPGRADE
if ( @ARGV < 1 )
@@ -409,10 +409,10 @@ if ( $OPT_UPGRADE )
print "Upgrading from postgis $libver\n";
- if ( '' ne $OPT_HOOK_BEFORE_UPGRADE )
+ foreach my $hook (@OPT_HOOK_BEFORE_UPGRADE)
- print "Running before-upgrade-script $OPT_HOOK_BEFORE_UPGRADE\n";
- die unless load_sql_file($OPT_HOOK_BEFORE_UPGRADE, 1);
+ print "Running before-upgrade-script $hook\n";
+ die unless load_sql_file($hook, 1);
create_upgrade_test_objects();
@@ -428,10 +428,10 @@ if ( $OPT_UPGRADE )
drop_upgrade_test_objects();
- if ( '' ne $OPT_HOOK_AFTER_UPGRADE )
+ foreach my $hook (@OPT_HOOK_AFTER_UPGRADE)
- print " Running after-upgrade-script $OPT_HOOK_AFTER_UPGRADE\n";
- die unless load_sql_file($OPT_HOOK_AFTER_UPGRADE, 1);
+ print " Running after-upgrade-script $hook\n";
# Update libver
@@ -486,12 +486,11 @@ our $TEST = "";
print "\nRunning tests\n\n";
-if ( '' ne $OPT_HOOK_AFTER_CREATE )
+foreach my $hook (@OPT_HOOK_AFTER_CREATE)
- start_test("after-create-script");
+ start_test("after-create-script $hook");
show_progress();
- pass("($OPT_HOOK_AFTER_CREATE)")
- if load_sql_file($OPT_HOOK_AFTER_CREATE, 1);
+ pass() if load_sql_file($hook, 1);
foreach $TEST (@ARGV)
@@ -574,12 +573,11 @@ foreach $TEST (@ARGV)
-if ( '' ne $OPT_HOOK_BEFORE_UNINSTALL )
+foreach my $hook (@OPT_HOOK_BEFORE_UNINSTALL)
- start_test("before-uninstall-script");
+ start_test("before-uninstall-script $hook");
show_progress();
- pass("($OPT_HOOK_BEFORE_UNINSTALL)")
- if load_sql_file($OPT_HOOK_BEFORE_UNINSTALL, 1);
@@ -658,12 +656,16 @@ Options:
--extension load using extensions
--after-create-script <path>
script to load after spatial db creation
+ (multiple switches supported, to be run in given order)
--before-uninstall-script <path>
script to load before spatial extension uninstall
--before-upgrade-script <path>
script to load before upgrade
--after-upgrade-script <path>
script to load after upgrade
Summary of changes:
regress/run_test.pl | 46 ++++++++++++++++++++++++----------------------
1 file changed, 24 insertions(+), 22 deletions(-)
hooks/post-receive
