[postgis-tickets] [PostGIS] #4873: PostGIS 3.1 / GEOS 3.9.dev
trac at osgeo.org
Tue Mar 9 12:00:59 PST 2021
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.1.2
Component: postgis | Version: 3.1.x
Keywords: |
I feel like we fixed this in PostGIS 3.2 (master) already. Maybe we
didn't backport?
PostgreSQL 12.2, compiled by Visual C++ build 1914, 64-bit
Postgis 3.1.2dev - (3.1.1-24-gcdd2818d0) - 2021-03-05 11:36:34
scripts 3.1.2dev 3.1.1-24-gcdd2818d0
raster scripts 3.1.2dev 3.1.1-24-gcdd2818d0
GEOS: 3.9.2dev-CAPI-1.14.2
PROJ: 7.1.1
SFCGAL: 1.3.8
GDAL: GDAL 3.2.1, released 2020/12/29
./regress/core/fixedoverlay .. failed (diff expected obtained:
/projects/postgis/tmp/3.1.2dev_pg12_geos3.9_gdal3.2.1w64/test_102_diff)
--- ./regress/core/fixedoverlay_expected 2020-12-16
12:09:06.112964000 -0500
+++ /projects/postgis/tmp/3.1.2dev_pg12_geos3.9_gdal3.2.1w64/test_102_out
2021-03-05 06:56:02.412996700 -0500
@@ -5,5 +5,4 @@
unaryunion|MULTILINESTRING((0 0,8 0),(8 0,10 0),(10 0,14 0))
subdivide|POLYGON((0 10,10 10,10 0,0 0,0 10))
subdivide|POLYGON((10 6,100 6,100 4,10 6))
-subdivide|POLYGON((100 4,110 4,110 0,100 0,100 4))
-subdivide|POLYGON((100 10,110 10,110 4,100 4,100 10))
+subdivide|POLYGON((100 10,110 10,110 0,100 0,100 10))
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4873>
