[postgis-tickets] [SCM] PostGIS branch stable-3.1 updated. 3.1.1-27-g792a90a
git at osgeo.org
git at osgeo.org
Tue Mar 9 19:56:41 PST 2021
the project "PostGIS".
The branch, stable-3.1 has been updated
via 792a90a7ac016fdaff1781f1192f6b62f7cf611c (commit)
from 2239a5c8efab280050163de6453f055346d69375 (commit)
revisions in full, below.
commit 792a90a7ac016fdaff1781f1192f6b62f7cf611c
Author: Sandro Santilli <strk at kbt.io>
Date: Wed Mar 3 22:45:57 2021 +0100
References #4837 for PostGIS 3.1
diff --git a/topology/sql/populate.sql.in b/topology/sql/populate.sql.in
index 7974182..38a83fa 100644
--- a/topology/sql/populate.sql.in
+++ b/topology/sql/populate.sql.in
@@ -293,15 +293,53 @@ BEGIN
RETURN rec.edge_id;
END IF;
- -- WARNING: the constructive operation might throw an exception
- BEGIN
- ix = ST_Intersection(rec.geom, aline);
- EXCEPTION
- WHEN OTHERS THEN
- RAISE NOTICE 'Could not compute intersection between input edge (%) and edge % (%)', aline::text, rec.edge_id, rec.geom::text;
- END;
- RAISE EXCEPTION 'Edge intersects (not on endpoints) with existing edge % at or near point %', rec.edge_id, ST_AsText(ST_PointOnSurface(ix));
+ -- WARNING: the constructive operation might throw an exception
+ BEGIN
+ ix = ST_Intersection(rec.geom, aline);
+ EXCEPTION
+ WHEN OTHERS THEN
+ RAISE NOTICE
+ 'Could not compute intersection between'
+ ' input edge (%) and edge % (%)',
+ aline::text,
+ rec.edge_id,
+ rec.geom::text;
+ END;
+ -- Find a point on the intersection which
+ -- is NOT an endpoint of "aline"
+ IF ST_Dimension(ix) = 0
+ THEN
+ WITH SharedBounds AS (
+ SELECT ST_Force2D(ST_StartPoint(rec.geom)) g
+ UNION
+ SELECT ST_Force2D(ST_EndPoint(rec.geom))
+ INTERSECT
+ SELECT ST_Force2D(ST_StartPoint(aline))
+ UNION
+ SELECT ST_Force2D(ST_EndPoint(aline))
+ SELECT d.geom
+ FROM ST_DumpPoints(ix) d
+ WHERE ST_Force2D(geom) NOT IN ( SELECT g FROM SharedBounds )
+ ORDER BY d.path
+ LIMIT 1
+ INTO STRICT ix;
+ ELSE
+ -- for linear intersection we pick
+ -- an internal point.
+ ix := ST_PointOnSurface(ix);
+ END IF;
+ RAISE EXCEPTION
+ 'Edge intersects (not on endpoints)'
+ ' with existing edge % at or near point %',
+ rec.edge_id,
+ ST_AsText(ix);
END LOOP;
diff --git a/topology/test/regress/addedge_expected b/topology/test/regress/addedge_expected
index 39be89d..19f7a2a 100644
--- a/topology/test/regress/addedge_expected
+++ b/topology/test/regress/addedge_expected
@@ -17,8 +17,8 @@ e5|5
e6|6
#770-1|7
#770-2|8
-ERROR: Edge intersects (not on endpoints) with existing edge 7 at or near point POINT(8 10)
+ERROR: Edge intersects (not on endpoints) with existing edge 7 at or near point POINT(10 12)
#770-1*|7
1|0|0|-1|1|LINESTRING(0 0,8 0)
Summary of changes:
topology/sql/populate.sql.in | 56 ++++++++++++++++++++++++++++------
topology/test/regress/addedge_expected | 4 +--
2 files changed, 49 insertions(+), 11 deletions(-)
hooks/post-receive
