[postgis-tickets] [PostGIS] #4876: PostgreSQL 14 regress failure on uninstall
trac at osgeo.org
Wed Mar 10 06:55:22 PST 2021
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.2.0
Component: postgis | Version: master
Keywords: |
https://debbie.postgis.net/job/PostGIS_Regress/16554/consoleFull
23:59:40 -------------- Compiler Info -------------
23:59:40 C compiler: gcc -std=gnu99 -g -O2 -fno-math-errno
-fno-signed-zeros
23:59:40 C++ compiler (Wagyu): gcc -std=c++11 -x c++
23:59:40 CPPFLAGS:
-I/var/lib/jenkins/workspace/geos/rel-3.10w64/include
-I/usr/include/libxml2 -I/usr/include -I/usr/include/json-c -DNDEBUG
23:59:40 LDFLAGS: -lm
23:59:40 SQL preprocessor: /usr/bin/cpp -traditional-cpp -w -P
23:59:40
23:59:40 -------------- Additional Info -------------
23:59:40 Interrupt Tests: DISABLED use: --with-interrupt-tests to
enable
23:59:40
23:59:40 -------------- Dependencies --------------
23:59:40 GEOS config:
/var/lib/jenkins/workspace/geos/rel-3.10w64/bin/geos-config
23:59:40 GEOS version: 3.10.0dev
23:59:40 GDAL config:
/var/lib/jenkins/workspace/gdal/rel-3.2w64/bin/gdal-config
23:59:40 GDAL version: 3.2.2
23:59:40 SFCGAL config: /usr/bin/sfcgal-config
23:59:40 SFCGAL version: 1.3.8
23:59:40 PostgreSQL config:
/var/lib/jenkins/workspace/pg/rel/pg14w64/bin/pg_config
23:59:40 PostgreSQL version: PostgreSQL 14devel
23:59:40 PROJ4 version: 72
23:59:40 Libxml2 config: /usr/bin/xml2-config
23:59:40 Libxml2 version: 2.9.10
23:59:40 JSON-C support: yes
23:59:40 protobuf support: yes
23:59:40 protobuf-c version: 1003003
23:59:40 PCRE support: no
23:59:40 Perl: /usr/bin/perl
23:59:40
23:59:40 --------------- Extensions ---------------
23:59:40 PostGIS Raster: enabled
23:59:40 PostGIS Topology: enabled
23:59:40 SFCGAL support: enabled
23:59:40 Address Standardizer support: disabled
23:59:40
23:59:40 -------- Documentation Generation --------
23:59:40 xsltproc: /usr/bin/xsltproc
23:59:40 xsl style sheets: /usr/share/xml/docbook/stylesheet
/docbook-xsl
23:59:40 dblatex: /usr/bin/dblatex
23:59:40 convert: /usr/bin/convert
23:59:40 mathml2.dtd:
/usr/share/xml/schema/w3c/mathml/dtd/mathml2.dtd
23:59:40
00:05:54 psql:/var/lib/jenkins/workspace/postgis/branches/3.2/regress/00
-regress-install/share/contrib/postgis/uninstall_postgis.sql:82: ERROR:
cannot drop operator @(geometry,geometry) because other objects depend on
it
00:05:54 DETAIL: constraint enforce_max_extent_rast on table loadedrast
depends on operator @(geometry,geometry)
00:05:54 HINT: Use DROP ... CASCADE to drop the dependent objects too.
00:05:54
00:05:54 . failed (Object count pre-install (5173) != post-uninstall
(6584))
00:05:54
00:05:54 Run tests: 293
00:05:54 Failed: 30
Started happening around 3/8 or so but hard to say what caused it.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4876>
