[postgis-tickets] [PostGIS] #4875: geosmakevalid failure on 3.0 with GEOS 3.9.2dev
trac at osgeo.org
Wed Mar 10 13:39:26 PST 2021
Reporter: robe | Owner: robe
Type: defect | Status: reopened
Priority: blocker | Milestone: PostGIS 3.0.4
Component: postgis | Version: 3.0.x
Resolution: | Keywords:
Changes (by robe):
* status: closed => reopened
* resolution: fixed =>
Comment:
This still is failing on debbie
https://debbie.postgis.net/job/PostGIS_Regress/16556/console
which makes me concerned that 3.8dev changed as well as the other bots
seem fine and the loop she is failing in I did not change. She's running
3.8.2dev
09:50:17 Expected: GEOMETRYCOLLECTION(POLYGON((92114.014
463463.469,92115.5120743 463462.206937,92115.512 463462.207,92127.546
463452.075,92117.173 463439.755,92133.675 463425.942,92122.136
463412.826,92092.377 463437.77,92114.014
463463.469)),MULTIPOINT(92115.5120743 463462.206937,92122.136 463412.826))
09:50:17 Obtained: GEOMETRYCOLLECTION(POLYGON((92092.377
463437.77,92114.014 463463.469,92115.5120743 463462.206937,92115.512
463462.207,92127.546 463452.075,92117.173 463439.755,92133.675
463425.942,92122.136 463412.826,92092.377 463437.77)),MULTIPOINT(92122.136
463412.826,92115.5120743 463462.206937))
09:50:17 FAILED
09:50:17 1. cu_geos.c:154 -
CU_ASSERT_STRING_EQUAL(out_ewkt,"GEOMETRYCOLLECTION(POLYGON((92114.014
463412.826))")
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4875#comment:2>
