[postgis-tickets] [PostGIS] #4878: check_tests_enabled files in parallel make
trac at osgeo.org
Wed Mar 10 15:20:56 PST 2021
Reporter: pramsey | Owner: strk
Type: defect | Status: assigned
Priority: high | Milestone: PostGIS 3.2.0
Component: postgis | Version: master
Keywords: |
After build, running the tests, use
make -j2 check
to get a parallel build of the tests, and see a failure
utils/check_tests_enabled.sh
The following tests are available but not enabled in:
- topology/test/tests.mk:
topology/test/regress/droptopogeometrycolumn
topology/test/regress/topogeom_addtopogeom
topology/test/regress/addedge
using -j1 the check proceeds as usual.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4878>
