[postgis-tickets] [PostGIS] #4876: PostgreSQL 14 regress failure on uninstall and raster regresses many
trac at osgeo.org
Wed Mar 10 18:04:01 PST 2021
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.2.0
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by robe):
old regresses now - related pull request -
https://git.osgeo.org/gitea/postgis/postgis/pulls/53
But as noted on the pull request - this broke dronie's upgrade test
because we changed the return type.
I still haven't retested on PG14 so hopefully that isn't broken
WARNING: 'postgis.gdal_enabled_drivers' is already set and cannot be
changed until you reconnect
WARNING: 'postgis.enable_outdb_rasters' is already set and cannot be
ERROR: cannot change return type of existing function
HINT: Use DROP FUNCTION _st_rastertoworldcoord(raster,integer,integer)
first.
make: *** [runtest.mk:10: check-regress] Error 1
make: Leaving directory '/drone/src/regress'
FAIL: upgrade 2.5.5--3.2.0dev
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4876#comment:5>
