[postgis-tickets] [PostGIS] #4880: ST_Azimuth with geography type returns incorrect value
PostGIS trac at osgeo.org
Thu Mar 11 07:00:44 PST 2021
 Reporter:  francoisb  |      Owner:  pramsey
     Type:  defect     |     Status:  new
 Priority:  medium     |  Milestone:  PostGIS 3.1.2
Component:  postgis    |    Version:  3.1.x
 Keywords:  angle      |
 It seems #4718 is a regression.
 Perfect west 270° (3π/2 rad) - the only value in the regression test from
 tickets.sql which had a negative result in the previous code - is by
 chance correct, but all other expected results in the range 180°-360°
 (π-2π rad) are incorrect.
 Second, a perfect north (value exactly 0) is now incorrectly returned as
 180° (π rad), instead of 0.
 The fix is simple. Expected formula in lwgeodetic.c line 2180 is:
         return az < 0 ? az + 2.0 * M_PI : az;
 instead of:
         return az > 0 ? az : M_PI - az;
 Regression test from tickets.sql should add additional values, say at 45°
 (Northeast, π/4) and at 315° (Northwest, 7π/4).
 Documentation for ST_Azimuth could be extended to read:
 North = 0; Northeast = π/4; East = π/2; Southeast = 3π/4; South = π;
 Southwest 5π/4; West = 3π/2; Northwest = 7π/4
 instead of:
 North = 0; East = π/2; South = π; West = 3π/2
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4880>
