[postgis-tickets] [SCM] PostGIS branch stable-3.1 updated. 3.1.1-29-g15713db
git at osgeo.org
git at osgeo.org
Thu Mar 11 14:29:13 PST 2021
the project "PostGIS".
The branch, stable-3.1 has been updated
via 15713db62a3cbacec5e2c28446e6c9b73e51c28f (commit)
from d2b6e27d15f0b931b5759384b7935afaa5648420 (commit)
revisions in full, below.
commit 15713db62a3cbacec5e2c28446e6c9b73e51c28f
Author: Regina Obe <lr at pcorp.us>
Date: Thu Mar 11 13:43:46 2021 -0500
Change raster to use returns table instead of out for multi row returns
Changes to raster regress to use lateral instead of select and other
fixes to regress on PostgreSQL 14. Paul Ramsey, Regina Obe
Closes #4876 for PostGIS 3.1.2
Closes https://git.osgeo.org/gitea/postgis/postgis/pulls/53
diff --git a/NEWS b/NEWS
index b6ad35b..2172241 100644
--- a/NEWS
+++ b/NEWS
@@ -14,6 +14,8 @@ PostGIS 3.1.2
- #4840, Improper conversion of negative geographic azimuth to positive (Paul Ramsey)
- #4853, DBSCAN cluster not formed when recordset length equal to minPoints (Dan Baston)
- #4863, Update bboxes after scale/affine coordinate changes (Paul Ramsey)
+ - #4876, Fix raster issues related to PostgreSQL 14 tablefunc changes
+ (Paul Ramsey, Regina Obe)
- #4877, mingw64 PostGIS / PostgreSQL 14 compile (Regina Obe, Tom Lane)
diff --git a/raster/rt_pg/rtpg_band_properties.c b/raster/rt_pg/rtpg_band_properties.c
index c5188f2..8ec500a 100644
--- a/raster/rt_pg/rtpg_band_properties.c
+++ b/raster/rt_pg/rtpg_band_properties.c
@@ -485,8 +485,9 @@ Datum RASTER_bandmetadata(PG_FUNCTION_ARGS)
bool isoutdb;
char *bandpath;
uint8_t extbandnum;
- uint64_t filesize;
- uint64_t timestamp;
+ uint64_t filesize;
+ uint64_t timestamp;
+ bool isnullband;
struct bandmetadata *bmd = NULL;
struct bandmetadata *bmd2 = NULL;
@@ -527,10 +528,29 @@ Datum RASTER_bandmetadata(PG_FUNCTION_ARGS)
/* switch to memory context appropriate for multiple function calls */
oldcontext = MemoryContextSwitchTo(funcctx->multi_call_memory_ctx);
+ /* Build a tuple descriptor for our result type */
+ if (get_call_result_type(fcinfo, NULL, &tupdesc) != TYPEFUNC_COMPOSITE) {
+ MemoryContextSwitchTo(oldcontext);
+ ereport(ERROR, (
+ errcode(ERRCODE_FEATURE_NOT_SUPPORTED),
+ errmsg(
+ "function returning record called in context "
+ "that cannot accept type record"
+ BlessTupleDesc(tupdesc);
+ funcctx->tuple_desc = tupdesc;
/* pgraster is null, return null */
if (PG_ARGISNULL(0)) {
+ bmd = (struct bandmetadata *) palloc(sizeof(struct bandmetadata));
+ bmd->isnullband = TRUE;
+ funcctx->user_fctx = bmd;
+ funcctx->max_calls = 1;
- SRF_RETURN_DONE(funcctx);
+ goto PER_CALL;
pgraster = (rt_pgraster *) PG_DETOAST_DATUM(PG_GETARG_DATUM(0));
@@ -549,8 +569,12 @@ Datum RASTER_bandmetadata(PG_FUNCTION_ARGS)
elog(NOTICE, "Raster provided has no bands");
rt_raster_destroy(raster);
PG_FREE_IF_COPY(pgraster, 0);
+ goto PER_CALL;
/* band index */
@@ -593,8 +617,12 @@ Datum RASTER_bandmetadata(PG_FUNCTION_ARGS)
pfree(bandNums);
+ goto PER_CALL;
bandNums[j] = idx;
@@ -611,7 +639,7 @@ Datum RASTER_bandmetadata(PG_FUNCTION_ARGS)
else if (j < n)
bandNums = repalloc(bandNums, sizeof(uint32_t) * j);
- bmd = (struct bandmetadata *) palloc(sizeof(struct bandmetadata) * j);
+ bmd = (struct bandmetadata *) palloc0(sizeof(struct bandmetadata) * j);
for (i = 0; i < j; i++) {
band = rt_raster_get_band(raster, bandNums[i] - 1);
@@ -619,8 +647,11 @@ Datum RASTER_bandmetadata(PG_FUNCTION_ARGS)
elog(NOTICE, "Could not get raster band at index %d", bandNums[i]);
+ bmd[0].isnullband = TRUE;
+ goto PER_CALL;
/* bandnum */
@@ -685,24 +716,11 @@ Datum RASTER_bandmetadata(PG_FUNCTION_ARGS)
/* total number of tuples to be returned */
funcctx->max_calls = j;
- /* Build a tuple descriptor for our result type */
- if (get_call_result_type(fcinfo, NULL, &tupdesc) != TYPEFUNC_COMPOSITE) {
- MemoryContextSwitchTo(oldcontext);
- ereport(ERROR, (
- errcode(ERRCODE_FEATURE_NOT_SUPPORTED),
- errmsg(
- "function returning record called in context "
- "that cannot accept type record"
- BlessTupleDesc(tupdesc);
- funcctx->tuple_desc = tupdesc;
+ PER_CALL:
/* stuff done on every call of the function */
funcctx = SRF_PERCALL_SETUP();
@@ -716,6 +734,14 @@ Datum RASTER_bandmetadata(PG_FUNCTION_ARGS)
Datum values[VALUES_LENGTH];
bool nulls[VALUES_LENGTH];
+ if (bmd2[0].isnullband) {
+ int i;
+ for (i = 0; i < VALUES_LENGTH; i++)
+ nulls[i] = TRUE;
+ result = HeapTupleGetDatum(heap_form_tuple(tupdesc, values, nulls));
+ SRF_RETURN_NEXT(funcctx, result);
memset(nulls, FALSE, sizeof(bool) * VALUES_LENGTH);
values[0] = UInt32GetDatum(bmd2[call_cntr].bandnum);
diff --git a/raster/rt_pg/rtpostgis.sql.in b/raster/rt_pg/rtpostgis.sql.in
index e7e491f..9adeb61 100644
--- a/raster/rt_pg/rtpostgis.sql.in
+++ b/raster/rt_pg/rtpostgis.sql.in
@@ -4527,32 +4527,36 @@ CREATE OR REPLACE FUNCTION ST_BandPixelType(rast raster, band integer DEFAULT 1)
AS 'MODULE_PATHNAME','RASTER_getBandPixelTypeName'
LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE;
+-- Changed: 3.1.2
CREATE OR REPLACE FUNCTION ST_BandMetaData(
rast raster,
- band int[],
- OUT bandnum int,
- OUT pixeltype text,
- OUT nodatavalue double precision,
- OUT isoutdb boolean,
- OUT path text,
- OUT outdbbandnum integer,
- OUT filesize bigint,
- OUT filetimestamp bigint
+ band int[])
+ RETURNS TABLE(
+ bandnum int,
+ pixeltype text,
+ nodatavalue double precision,
+ isoutdb boolean,
+ path text,
+ outdbbandnum integer,
+ filesize bigint,
+ filetimestamp bigint
AS 'MODULE_PATHNAME','RASTER_bandmetadata'
+-- Changed: 3.1.2
rast raster,
- band int DEFAULT 1,
- OUT path text,
+ band int DEFAULT 1)
+ RETURNS TABLE (
+ pixeltype text,
+ isoutdb boolean,
+ path text,
+ filesize bigint,
AS $$ SELECT pixeltype, nodatavalue, isoutdb, path, outdbbandnum, filesize, filetimestamp FROM @extschema at .ST_BandMetaData($1, ARRAY[$2]::int[]) LIMIT 1 $$
LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE;
@@ -4625,47 +4629,55 @@ CREATE OR REPLACE FUNCTION st_pixelofvalue(
rast raster,
nband integer,
search double precision[],
- exclude_nodata_value boolean DEFAULT TRUE,
- OUT val double precision,
- OUT x integer,
- OUT y integer
- RETURNS SETOF record
+ exclude_nodata_value boolean DEFAULT TRUE
+ RETURNS
+ TABLE(
+ val double precision,
+ x integer,
+ y integer
AS 'MODULE_PATHNAME', 'RASTER_pixelOfValue'
+-- Changed: 3.1.2
CREATE OR REPLACE FUNCTION ST_PixelofValue(
rast raster,
- OUT x integer,
- OUT y integer
+ RETURNS TABLE (
+ x integer,
+ y integer
AS $$ SELECT val, x, y FROM @extschema at .ST_PixelOfValue($1, 1, $2, $3) $$
+-- Changed: 3.1.2
rast raster,
nband integer,
search double precision,
- OUT x integer,
- OUT y integer
+ RETURNS TABLE (
+ x integer,
+ y integer
AS $$ SELECT x, y FROM @extschema at .ST_PixelofValue($1, $2, ARRAY[$3], $4) $$
+-- Changed: 3.1.2
rast raster,
- OUT x integer,
- OUT y integer
+ RETURNS TABLE (
+ x integer,
+ y integer
AS $$ SELECT x, y FROM @extschema at .ST_PixelOfValue($1, 1, ARRAY[$2], $3) $$
@@ -5041,11 +5053,11 @@ CREATE OR REPLACE FUNCTION st_dumpaspolygons(rast raster, band integer DEFAULT 1
-- ST_DumpValues
+-- Changed: 3.1.2
CREATE OR REPLACE FUNCTION st_dumpvalues(
- rast raster, nband integer[] DEFAULT NULL, exclude_nodata_value boolean DEFAULT TRUE,
- OUT nband integer, OUT valarray double precision[][]
+ rast raster, nband integer[] DEFAULT NULL, exclude_nodata_value boolean DEFAULT TRUE
+ RETURNS TABLE(nband integer, valarray double precision[][])
AS 'MODULE_PATHNAME','RASTER_dumpValues'
LANGUAGE 'c' IMMUTABLE PARALLEL SAFE;
@@ -5068,31 +5080,35 @@ CREATE OR REPLACE FUNCTION st_polygon(rast raster, band integer DEFAULT 1)
-- Should be called like this:
-- SELECT (gv).geom, (gv).val FROM (SELECT ST_PixelAsPolygons(rast) gv FROM mytable) foo
+-- Changed: 3.1.2
CREATE OR REPLACE FUNCTION _st_pixelaspolygons(
rast raster,
band integer DEFAULT 1,
columnx integer DEFAULT NULL,
rowy integer DEFAULT NULL,
- OUT geom geometry,
- OUT x integer,
- OUT y integer
+ RETURNS TABLE(
+ geom geometry,
+ x integer,
+ y integer
AS 'MODULE_PATHNAME', 'RASTER_getPixelPolygons'
+-- Changed: 3.1.2
CREATE OR REPLACE FUNCTION st_pixelaspolygons(
rast raster,
- OUT x int,
- OUT y int
+ RETURNS TABLE (
+ geom geometry,
+ x int,
+ y int
AS $$ SELECT geom, val, x, y FROM @extschema at ._ST_pixelaspolygons($1, $2, NULL, NULL, $3) $$
@@ -5108,17 +5124,18 @@ CREATE OR REPLACE FUNCTION st_pixelaspolygon(rast raster, x integer, y integer)
-- ST_PixelAsPoints
+-- Changed: 3.1.2
CREATE OR REPLACE FUNCTION st_pixelaspoints(
rast raster,
- OUT x int,
- OUT y int
+ RETURNS TABLE (
+ geom geometry,
+ x int,
+ y int
AS $$ SELECT @extschema at .ST_PointN( @extschema at .ST_ExteriorRing(geom), 1), val, x, y FROM @extschema at ._ST_pixelaspolygons($1, $2, NULL, NULL, $3) $$
@@ -5134,17 +5151,17 @@ CREATE OR REPLACE FUNCTION st_pixelaspoint(rast raster, x integer, y integer)
-- ST_PixelAsCentroids
+-- Changed: 3.1.2
CREATE OR REPLACE FUNCTION st_pixelascentroids(
rast raster,
- OUT x int,
- OUT y int
+ exclude_nodata_value boolean DEFAULT TRUE)
+ RETURNS TABLE (
+ geom geometry,
+ x int,
+ y int
AS $$ SELECT @extschema at .ST_Centroid(geom), val, x, y FROM @extschema at ._ST_pixelaspolygons($1, $2, NULL, NULL, $3) $$
@@ -5169,8 +5186,8 @@ CREATE OR REPLACE FUNCTION _st_worldtorastercoord(
rast raster,
longitude double precision DEFAULT NULL, latitude double precision DEFAULT NULL,
OUT columnx integer,
- OUT rowy integer
+ OUT rowy integer)
+ RETURNS record
AS 'MODULE_PATHNAME', 'RASTER_worldToRasterCoord'
@@ -5184,8 +5201,8 @@ CREATE OR REPLACE FUNCTION st_worldtorastercoord(
rast raster,
longitude double precision, latitude double precision,
- OUT rowy integer
+ OUT rowy integer)
+ RETURNS record
AS $$ SELECT columnx, rowy FROM @extschema at ._ST_worldtorastercoord($1, $2, $3) $$
@@ -5197,9 +5214,8 @@ CREATE OR REPLACE FUNCTION st_worldtorastercoord(
rast raster, pt geometry,
- OUT rowy integer
- AS
+ OUT rowy integer)
+ RETURNS record AS
DECLARE
rx integer;
@@ -5315,13 +5331,12 @@ CREATE OR REPLACE FUNCTION st_worldtorastercoordy(rast raster, pt geometry)
-- ST_RasterToWorldCoord
CREATE OR REPLACE FUNCTION _st_rastertoworldcoord(
rast raster,
columnx integer DEFAULT NULL, rowy integer DEFAULT NULL,
OUT longitude double precision,
OUT latitude double precision
+ ) RETURNS record
AS 'MODULE_PATHNAME', 'RASTER_rasterToWorldCoord'
@@ -5332,12 +5347,13 @@ CREATE OR REPLACE FUNCTION _st_rastertoworldcoord(
-- This function works even if the provided raster column and row are beyond or
-- below the raster width and height.
+-- Changed: 3.1.2
CREATE OR REPLACE FUNCTION st_rastertoworldcoord(
rast raster,
columnx integer, rowy integer,
- OUT longitude double precision,
+ OUT longitude double precision,
+ ) RETURNS record
AS $$ SELECT longitude, latitude FROM @extschema at ._ST_rastertoworldcoord($1, $2, $3) $$
@@ -8203,10 +8219,14 @@ CREATE OR REPLACE FUNCTION _overview_constraint(ov raster, factor integer, refsc
LANGUAGE 'sql' STABLE
COST 100;
+-- Changed: 3.1.2
CREATE OR REPLACE FUNCTION _overview_constraint_info(
ovschema name, ovtable name, ovcolumn name,
- OUT refschema name, OUT reftable name, OUT refcolumn name, OUT factor integer
+ OUT refschema name,
+ OUT reftable name,
+ OUT refcolumn name,
+ OUT factor integer
AS $$
SELECT
split_part(split_part(s.consrc, '''::name', 1), '''', 2)::name,
@@ -8223,7 +8243,7 @@ CREATE OR REPLACE FUNCTION _overview_constraint_info(
AND s.connamespace = n.oid
AND s.conrelid = c.oid
AND a.attnum = ANY (s.conkey)
- AND s.consrc LIKE '%_overview_constraint(%'
+ AND s.consrc LIKE '%_overview_constraint(%' LIMIT 1
$$ LANGUAGE sql STABLE STRICT
COST 100;
diff --git a/raster/test/regress/rt_asraster.sql b/raster/test/regress/rt_asraster.sql
index 548cc97..88c58f0 100644
--- a/raster/test/regress/rt_asraster.sql
+++ b/raster/test/regress/rt_asraster.sql
@@ -483,15 +483,18 @@ SELECT
FROM (
SELECT
d.rid,
- (ST_MetaData(d.rast)).*,
- (ST_SummaryStats(d.rast)).*,
- (ST_BandMetaData(d.rast)).*,
+ mda.*,
+ ssum.*,
+ bmd.*,
CASE
WHEN d.rid LIKE '4.%'
THEN ST_SameAlignment(ST_Transform(d.rast, 992163), r.rast)
ELSE NULL
END AS same_alignment
FROM raster_asraster_dst d
+ LEFT JOIN LATERAL ST_MetaData(d.rast) AS mda ON true
+ LEFT JOIN LATERAL ST_SummaryStats(d.rast) AS ssum ON true
+ LEFT JOIN LATERAL ST_BandMetaData(d.rast) AS bmd ON true
CROSS JOIN raster_asraster_rast r
ORDER BY d.rid
) foo;
diff --git a/raster/test/regress/rt_bandmetadata.sql b/raster/test/regress/rt_bandmetadata.sql
index ed9b852..3070ace 100644
--- a/raster/test/regress/rt_bandmetadata.sql
+++ b/raster/test/regress/rt_bandmetadata.sql
@@ -98,7 +98,7 @@ FROM ST_BandMetaData(
SELECT
- bandnum
+ bandnum,
pixeltype,
round(nodatavalue::numeric, 3),
isoutdb,
@@ -110,7 +110,7 @@ FROM ST_BandMetaData(
SELECT
- bandnum
+ bandnum,
pixeltype,
isoutdb,
diff --git a/raster/test/regress/rt_bandmetadata_expected b/raster/test/regress/rt_bandmetadata_expected
index 8458aac..2047367 100644
--- a/raster/test/regress/rt_bandmetadata_expected
+++ b/raster/test/regress/rt_bandmetadata_expected
@@ -5,11 +5,11 @@
8BUI|4.000|f||
NOTICE: Invalid band index: 6. Indices must be 1-based. Returning NULL
-1|1.000|f||
-2|2.000|f||
-5|5.000|f||
-1|1.000|f||
-2|2.000|f||
-3|3.000|f||
-4|4.000|f||
-5|5.000|f||
+1|8BUI|1.000|f||
+2|8BUI|2.000|f||
+5|8BUI|5.000|f||
+1|8BUI|1.000|f||
+2|8BUI|2.000|f||
+3|8BUI|3.000|f||
+4|8BUI|4.000|f||
+5|8BUI|5.000|f||
diff --git a/raster/test/regress/rt_clip.sql b/raster/test/regress/rt_clip.sql
index d50eb31..bae2cb3 100644
--- a/raster/test/regress/rt_clip.sql
+++ b/raster/test/regress/rt_clip.sql
@@ -116,9 +116,11 @@ FROM (
SELECT tid,
rid,
gid,
- (ST_Metadata(rast)).*,
- (ST_BandMetadata(rast, 1)).*
+ md.*,
+ bmd.*
FROM raster_clip_out
+ LEFT JOIN LATERAL ST_Metadata(rast) AS md ON true
+ LEFT JOIN LATERAL ST_BandMetadata(rast, 1) AS bmd ON true
) AS r;
-- Display the pixels and the values of the resulting rasters (raster 1)
@@ -130,8 +132,8 @@ SELECT
(gvxy).y,
(gvxy).val,
ST_AsText((gvxy).geom) geom
-FROM (SELECT tid, rid, gid, ST_PixelAsPolygons(rast) gvxy
- FROM raster_clip_out
+FROM (SELECT tid, rid, gid, gvxy
+ FROM raster_clip_out, ST_PixelAsPolygons(rast) AS gvxy
WHERE rid = 1
) foo
ORDER BY 1, 2, 3, 4, 5, 7;
@@ -146,8 +148,9 @@ SELECT
(gvxy).y,
(gvxy).val,
-FROM (SELECT tid, rid, gid, band, ST_PixelAsPolygons(rast, band) gvxy
- FROM raster_clip_out, generate_series(1, 3) band
+FROM (SELECT tid, rid, gid, band, gvxy
+ FROM raster_clip_out, generate_series(1, 3) band,
+ ST_PixelAsPolygons(rast, band) AS gvxy
WHERE rid = 2
) foo
ORDER BY 1, 2, 3, 4, 5, 6, 8;
diff --git a/raster/test/regress/rt_intersection.sql b/raster/test/regress/rt_intersection.sql
index 1dd9a48..8d86d0b 100644
--- a/raster/test/regress/rt_intersection.sql
+++ b/raster/test/regress/rt_intersection.sql
@@ -134,11 +134,13 @@ FROM (
SELECT
rid1,
rid2,
- (ST_BandMetadata(rast, 1)).*,
+ md.*,
+ bmd.*,
ST_Value(rast, 1, 1, 1) AS firstvalue,
ST_Value(rast, 1, ST_Width(rast), ST_Height(rast)) AS lastvalue
FROM raster_intersection_out
+ LEFT JOIN LATERAL ST_BandMetadata(rast,1) AS bmd ON true
) AS r;
@@ -155,9 +157,10 @@ FROM (
rid1,
rid2,
band,
- ST_PixelAsPolygons(rast, band) gvxy
+ gvxy
- CROSS JOIN generate_series(1, 2) band
+ CROSS JOIN generate_series(1, 2) AS band
+ CROSS JOIN ST_PixelAsPolygons(rast, band) AS gvxy
) foo
ORDER BY 1, 2, 3, 4, 5, 6, 7;
diff --git a/raster/test/regress/rt_mapalgebra_expected b/raster/test/regress/rt_mapalgebra_expected
index d669125..a7753a7 100644
--- a/raster/test/regress/rt_mapalgebra_expected
+++ b/raster/test/regress/rt_mapalgebra_expected
@@ -72,6 +72,7 @@ NOTICE: userargs = {3.14}
NOTICE: All input rasters do not have bands at indicated indexes. Returning empty raster
NOTICE: Raster provided has no bands
NOTICE: Could not find raster band of index 1 when getting pixel value. Returning NULL
+NOTICE: Could not find raster band of index 1 when getting pixel value. Returning NULL
NOTICE: value = {{{NULL,NULL,NULL},{NULL,200,200},{NULL,200,200}}}
NOTICE: pos = [0:1][1:2]={{1,1},{1,1}}
NOTICE: userargs = <NULL>
diff --git a/raster/test/regress/rt_mapalgebra_expr.sql b/raster/test/regress/rt_mapalgebra_expr.sql
index 419e917..240deb8 100644
--- a/raster/test/regress/rt_mapalgebra_expr.sql
+++ b/raster/test/regress/rt_mapalgebra_expr.sql
@@ -425,11 +425,13 @@ FROM (
rid1,
rid2,
extent,
+ md.*,
+ bmd.*,
FROM raster_mapalgebra_out
) AS r;
DROP TABLE IF EXISTS raster_mapalgebra;
diff --git a/raster/test/regress/rt_mapalgebraexpr_2raster.sql b/raster/test/regress/rt_mapalgebraexpr_2raster.sql
index 3f0c416..58adc26 100644
--- a/raster/test/regress/rt_mapalgebraexpr_2raster.sql
+++ b/raster/test/regress/rt_mapalgebraexpr_2raster.sql
@@ -260,11 +260,13 @@ FROM (
rid1,
rid2,
extent,
+ mda.*,
+ bmd.*,
+ LEFT JOIN LATERAL ST_Metadata(rast) AS mda ON true
) AS r;
diff --git a/raster/test/regress/rt_mapalgebraexpr_2raster_expected b/raster/test/regress/rt_mapalgebraexpr_2raster_expected
index 3e3e6b4..5665de3 100644
--- a/raster/test/regress/rt_mapalgebraexpr_2raster_expected
+++ b/raster/test/regress/rt_mapalgebraexpr_2raster_expected
@@ -47,91 +47,69 @@ NOTICE: The SECOND raster is NULL. Returning NULL
NOTICE: The two rasters provided are NULL. Returning NULL
-NOTICE: Raster provided has no bands
0|1|INTERSECTION|0.000|0.000|2|2|1.000|1.000|0.000|0.000|0|1|32BF|0.000|1.000|1.000
diff --git a/raster/test/regress/rt_mapalgebrafct_2raster.sql b/raster/test/regress/rt_mapalgebrafct_2raster.sql
index 7e5fb97..1febc7b 100644
--- a/raster/test/regress/rt_mapalgebrafct_2raster.sql
+++ b/raster/test/regress/rt_mapalgebrafct_2raster.sql
@@ -328,11 +328,13 @@ FROM (
rid1,
rid2,
extent,
+ mda.*,
+ bmd.*,
) AS r;
DROP FUNCTION IF EXISTS raster_mapalgebra_intersection(double precision, double precision, int[], VARIADIC text[]);
diff --git a/raster/test/regress/rt_mapalgebrafct_2raster_expected b/raster/test/regress/rt_mapalgebrafct_2raster_expected
index a658252..b819327 100644
--- a/raster/test/regress/rt_mapalgebrafct_2raster_expected
+++ b/raster/test/regress/rt_mapalgebrafct_2raster_expected
@@ -65,91 +65,69 @@ NOTICE: The SECOND raster is NULL. Returning NULL
Summary of changes:
NEWS | 2 +
raster/rt_pg/rtpg_band_properties.c | 70 +++++---
raster/rt_pg/rtpostgis.sql.in | 198 ++++++++++++---------
raster/test/regress/rt_asraster.sql | 9 +-
raster/test/regress/rt_bandmetadata.sql | 4 +-
raster/test/regress/rt_bandmetadata_expected | 16 +-
raster/test/regress/rt_clip.sql | 15 +-
raster/test/regress/rt_intersection.sql | 11 +-
raster/test/regress/rt_mapalgebra_expected | 1 +
raster/test/regress/rt_mapalgebra_expr.sql | 6 +-
raster/test/regress/rt_mapalgebraexpr_2raster.sql | 6 +-
.../regress/rt_mapalgebraexpr_2raster_expected | 22 ---
raster/test/regress/rt_mapalgebrafct_2raster.sql | 6 +-
.../test/regress/rt_mapalgebrafct_2raster_expected | 22 ---
14 files changed, 204 insertions(+), 184 deletions(-)
hooks/post-receive
