[postgis-tickets] [PostGIS] #4881: Lineal TopoGeometry objects do not preserve their direction
trac at osgeo.org
Mon Mar 15 10:35:15 PDT 2021
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.2
Component: topology | Version: 1.5.X
Resolution: | Keywords:
Comment (by strk):
I spoke too early: while the TopoGeometry::Geometry cast IS BOGUS as
verified by manually changing sign of the {{{ element_id }}} fields in the
{{{ relation }}} table, the toTopoGeom function is ALSO BOGUS in that it
doesn't correctly set those {{{ element_id }}} field signs, see #4884
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4881#comment:3>
