[postgis-tickets] [PostGIS] #4890: ST_Transform large slow down from upgrade to 3.1.1 from 2.4
trac at osgeo.org
Sun Mar 28 13:37:55 PDT 2021
Reporter: SAbernethy | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.2
Component: postgis | Version: 3.1.x
Keywords: |
The issue is that the ST_Transform function inside postgis when upgraded
from 2.4 to either 3.0.3 or 3.1.1 runs about 20 times slower. This is
regardless of the version of postgres, We are currently running PG11 and
are upgrading to PG13 and are having to upgrade postgis version due to 2.4
not being supported in PG13.
Attached is the timings for the diffrent postgis
How to reproduce
setup postgres either 11 or 13,
install postgis version 2.4 / 3.03 / 3.11
create empty database
install posgis
and run the following query "select
ST_Transform('0103000020C90800000100000005000000000000008
CAE264100000000BCA34641000000008CAE264100000000CDA3464100
000000C2AE264100000000CDA3464100000040C3AE264100000000BCA
34641000000008CAE264100000000BCA34641'::geometry,4326);"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4890>
