[postgis-tickets] [PostGIS] #4891: debbie GDAL build broken
PostGIS trac at osgeo.org
Mon Mar 29 10:55:55 PDT 2021
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  blocker    |  Milestone:  Website Management, Bots
Component:  buildbots  |    Version:  master
 Keywords:             |
 Looks like my patch upgrade on debbie broke her ability to compile GDAL.
 Throwing this GDAL error
 -DHAVE_AVX_AT_COMPILE_TIME -DHAVE_SSSE3_AT_COMPILE_TIME
 -DHAVE_SSE_AT_COMPILE_TIME -g -O2  -Wall -Wextra -Winit-self -Wunused-
 parameter -Wformat -Werror=format-security -Wno-format-nonliteral
 -Wlogical-op -Wshadow -Werror=vla -Wdate-time -Wnull-dereference
 -Wduplicated-cond -Wextra-semi -Wfloat-conversion -Wmissing-declarations
 -Wnon-virtual-dtor -Woverloaded-virtual -fno-operator-names -Wzero-as-
 null-pointer-constant -Wsuggest-override -Wimplicit-fallthrough  -I. -I..
 -I../.. -I../../.. -DGNM_ENABLED
 -I/var/lib/jenkins/workspace/gdal/branches/3.2/gdal/port
 -DGDAL_COMPILATION -c -o ../../../o/r2000.lo r2000.cpp
 r2000.cpp: In member function ‘virtual int
 DWGFileR2000::ReadSectionLocators()’:
 r2000.cpp:3846:17: error: ‘readRecord’ was not declared in this scope; did
 you mean ‘readedRecord’?
  3846 |         FromLSB(readRecord.dSeeker);
       |                 readedRecord
 I'm retrying again before I investigate further.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4891>
