[postgis-tickets] [PostGIS] #4892: Debbie can't compile GDAL Master (GDAL 3.3)
PostGIS trac at osgeo.org
Mon Mar 29 15:06:50 PDT 2021
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  Website Management, Bots
 Component:  buildbots  |    Version:  master
Resolution:             |   Keywords:
Comment (by robe):
 This stackoverflow suggests it's because of Python 2 and only supported in
 Python 3
 https://stackoverflow.com/questions/12541370/typeerror-encoding-is-an-
 invalid-keyword-argument-for-this-function
 The terminal you are trying to run this on probably uses Python 2.x as
 standard.
 Try using the command "Python3" specifically in the terminal:
 $ Python3 yourfile.py
 (Tested and confirmed that 2.7 will give that error and that Python3
 handles it just fine.)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4892#comment:1>
