[postgis-tickets] [PostGIS] #5016: loader/Makefile.in does not respect LDFLAGS
trac at osgeo.org
Mon Nov 1 06:46:54 PDT 2021
Reporter: gdt | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.5
Component: postgis | Version: 2.5.x
Keywords: |
While building 3.1.4 under pkgsrc, I got an error that RELRO was missing
from shp2pgsql and pgsql2shp. Reading the build system, this appears to
be because @LDFLAGS@ is not carried to the link line. There is $(LDFLAGS)
on the link invocation, and many other LDFLAGS_FOO are set, but nowhere is
LDFLAGS=@LDFLAG.
I added simply "LDFLAGS = @LDFLAGS@" (as a new stanza after the one that
sets LIBTOOL), and this causes the RELRO LDFLAGS passed in from pkgsrc to
make it to the link lines.
I'm leaving this as medium because this will cause postgis to fail to
build in all packaging systems that apply hardening measures via LDFLAGS
(which is common) and then check that they have taken effect, and silently
fail to have the hardening measures in ones that don't check.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5016>
