[postgis-tickets] [PostGIS] #5017: topology.ValidateTopology error relation "shell_check" already exists
trac at osgeo.org
Tue Nov 9 01:35:46 PST 2021
Reporter: laopsahl | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.5
Component: postgis | Version: 2.5.x
Resolution: | Keywords:
Comment (by strk):
I cannot reproduce. What version of postgis ?
strk=# begin;
BEGIN
strk=# select * from validatetopology('city_data');
NOTICE: Checking for coincident nodes
NOTICE: Checking for edges crossing nodes
NOTICE: Checking for invalid or not-simple edges
NOTICE: Checking for crossing edges
NOTICE: Checking for edges start_node mismatch
NOTICE: Checking for edges end_node mismatch
NOTICE: Checking for faces without edges
NOTICE: Checking edge linking
NOTICE: Building edge rings
NOTICE: Found 315 rings, 310 valid shells, 5 valid holes
NOTICE: Constructing geometry of all faces
NOTICE: Checking faces
NOTICE: Checked 310 faces
NOTICE: Checking for holes coverage
NOTICE: Finished checking for coverage of 5 holes
NOTICE: Checking for node containing_face correctness
error | id1 | id2
(0 rows)
error | id1 | id2
(0 rows)
strk=# select postgis_full_version();
POSTGIS="3.2.0dev 3.2.0alpha1-53-g6c2131ddc" [EXTENSION] PGSQL="120"
GEOS="3.10.0-CAPI-1.16.0" PROJ="7.1.0" GDAL="GDAL 3.2.2, released
2021/03/05" LIBXML="2.9.10" LIBJSON="0.15" LIBPROTOBUF="1.3.3"
WAGYU="0.5.0 (Internal)" (core procs from "3.2.0dev
3.1.0rc1-392-g4f6e4bd36" need upgrade) TOPOLOGY (topology procs from
"3.2.0dev 3.1.0rc1-392-g4f6e4bd36" need upgrade) RASTER (raster procs from
(1 row)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5017#comment:1>
