[postgis-tickets] [PostGIS] #5017: topology.ValidateTopology error relation "shell_check" already exists
trac at osgeo.org
Tue Nov 9 05:13:46 PST 2021
Reporter: laopsahl | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.5
Component: postgis | Version: 2.5.x
Resolution: | Keywords:
Comment (by strk):
I can reproduce. It occurs when topology errors are found:
NOTICE: Checking for coincident nodes
NOTICE: Checking for edges crossing nodes
NOTICE: Checking for invalid or not-simple edges
NOTICE: Checking for crossing edges
NOTICE: Checking for edges start_node mismatch
NOTICE: Checking for edges end_node mismatch
NOTICE: Checking for faces without edges
NOTICE: Checking edge linking
NOTICE: Building edge rings
NOTICE: Found 315 rings, 309 valid shells, 5 valid holes
error | id1 | id2
mixed face labeling in ring | -153 |
(1 row)
strk=# select * from validateTopology('city_data');
ERROR: relation "shell_check" already exists
CONTEXT: SQL statement "CREATE TEMP TABLE shell_check (
face_id int PRIMARY KEY,
ring_geom geometry
PL/pgSQL function _validatetopologyrings(geometry) line 12 at SQL
statement
PL/pgSQL function validatetopology(character varying,geometry) line 300 at
FOR over SELECT rows
Your errors are actual errors, not just missing data
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5017#comment:5>
