[postgis-tickets] [PostGIS] #5018: pgsql2shp doesn't work with CTE queries (aka WITH)
trac at osgeo.org
Wed Nov 10 12:00:52 PST 2021
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.5
Component: loader/dumper | Version: 3.1.x
Keywords: |
https://lists.osgeo.org/pipermail/postgis-users/2021-November/045047.html
From the mailing list:
> > $ pgsql2shp ... "WITH foo AS (SELECT 2) SELECT 1"
> > Table WITH foo AS (SELECT 2) SELECT 1 does not exist
I found a work-around:
> $ pgsql2shp ... "SELECT * FROM (WITH foo AS (SELECT 2) SELECT 1) bar"
> Initializing...
> Done (postgis major version: 3).
> Output shape: Null Shape
> Dumping: X [1 rows].
The issue is this line:
https://git.osgeo.org/gitea/postgis/postgis/src/branch/master/loader
/pgsql2shp-cli.c#L140
Which explicitly looks for a SELECT to determine whether to treat the
input as a table or query.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5018>
