[postgis-tickets] [PostGIS] #5020: st_3dintersection causing core dump
PostGIS trac at osgeo.org
Sun Nov 14 01:02:11 PST 2021
 Reporter:  cege               |      Owner:  pramsey
     Type:  defect             |     Status:  new
 Priority:  high               |  Milestone:  PostGIS 3.1.5
Component:  postgis            |    Version:  2.5.x
 Keywords:  st_3dintersection  |
 PostgreSQL 13.4 on x86_64-pc-linux-gnu, compiled by gcc (GCC) 8.4.1
 20200928 (Red Hat 8.4.1-1), 64-bit
 "POSTGIS="3.1.4 ded6c34" [EXTENSION] PGSQL="130" GEOS="3.9.1-CAPI-1.14.2"
 SFCGAL="1.3.7" PROJ="8.1.0" LIBXML="2.9.7" LIBJSON="0.13.1"
 LIBPROTOBUF="1.3.0" WAGYU="0.5.0 (Internal)""
 Running st_3dintersection on the above configuration fails and causes a
 core dump in the database.  See attached for sample data creation and
 query scripts.
 (This same query works fine on the following configuration:
 POSTGRES: "PostgreSQL 10.19 (Ubuntu 10.19-0ubuntu0.18.04.1) on x86_64-pc-
 linux-gnu, compiled by gcc (Ubuntu 7.5.0-3ubuntu1~18.04) 7.5.0, 64-bit"
 POSTGIS: POSTGIS="2.5.3 r17699" [EXTENSION] PGSQL="100"
 GEOS="3.7.0-CAPI-1.11.0 673b9939" SFCGAL="1.3.7" PROJ="Rel. 5.2.0,
 September 15th, 2018" GDAL="GDAL 2.4.0, released 2018/12/14"
 LIBXML="2.9.4" LIBJSON="0.12.1" RASTER
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5020>
