[postgis-tickets] [SCM] PostGIS branch stable-3.1 updated. 3.1.4-15-ge813b8262
git at osgeo.org
git at osgeo.org
Fri Nov 19 16:11:01 PST 2021
the project "PostGIS".
The branch, stable-3.1 has been updated
via e813b8262481dbf58651750502a25bb44fdd3f0e (commit)
via bbc82305dc4f443d347014983a77c84d284ae6f3 (commit)
from 8acb5e033cad2502bac5a0a8bf8a107cfbeabedb (commit)
revisions in full, below.
commit e813b8262481dbf58651750502a25bb44fdd3f0e
Author: Regina Obe <lr at pcorp.us>
Date: Fri Nov 19 19:10:54 2021 -0500
Change berrie to test pg13 instead of 12
diff --git a/ci/berrie/postgis_regress.sh b/ci/berrie/postgis_regress.sh
index 6cd74363f..3f28dbd86 100644
--- a/ci/berrie/postgis_regress.sh
+++ b/ci/berrie/postgis_regress.sh
@@ -9,7 +9,7 @@ export WORKSPACE=/home/jenkins/workspace
cd ${WORKSPACE}/PostGIS_Worker_Run/label/${label}/$BRANCH
export OS_BUILD=32
-export PG_VER=12
+export PG_VER=13
export PGPATH=${WORKSPACE}/pg/label/${label}/rel/pg${PG_VER}w${OS_BUILD}
export PATH=${PGPATH}/bin:${PGPATH}/lib:${PATH}
commit bbc82305dc4f443d347014983a77c84d284ae6f3
Date: Fri Nov 19 19:10:29 2021 -0500
Prevent duplicate links in Aggregate section. Closes #5021 for PostGIS 3.1
diff --git a/doc/xsl/postgis_aggs_mm.xml.xsl b/doc/xsl/postgis_aggs_mm.xml.xsl
index 150dbc921..11e2c90d2 100644
--- a/doc/xsl/postgis_aggs_mm.xml.xsl
+++ b/doc/xsl/postgis_aggs_mm.xml.xsl
@@ -34,14 +34,11 @@
</xsl:variable>
<!-- For each function prototype if it takes a geometry set then catalog it as an aggregate function -->
- <xsl:for-each select="refsynopsisdiv/funcsynopsis/funcprototype">
- <xsl:choose>
- <xsl:when test="contains(paramdef/type,' set') or contains(paramdef/type,'geography set') or contains(paramdef/type,'raster set')">
+ <xsl:if test=".//paramdef[contains(type,' set')] or .//paramdef[contains(type,'geography set')] or
+ .//paramdef[contains(type,'raster set')]">
<listitem><simpara><link linkend="{$refid}"><xsl:value-of select="$refname" /></link> - <xsl:value-of select="$comment" /></simpara></listitem>
- </xsl:when>
- </xsl:choose>
+ </xsl:if>
</xsl:for-each>
- </xsl:for-each>
</itemizedlist>
</sect1>
@@ -583,7 +580,7 @@
</itemizedlist>
</xsl:if>
</sect2>
<sect2 id="NewFunctions_3_0">
<title>PostGIS Functions new or enhanced in 3.0</title>
<para>The functions given below are PostGIS functions that were added or enhanced.</para>
Summary of changes:
ci/berrie/postgis_regress.sh | 2 +-
doc/xsl/postgis_aggs_mm.xml.xsl | 11 ++++-------
2 files changed, 5 insertions(+), 8 deletions(-)
hooks/post-receive
