[postgis-tickets] [PostGIS] #5023: berrie64 failing on garden tests ST_MaximumInscribedCircle with malformed geometries
trac at osgeo.org
Mon Nov 22 19:11:16 PST 2021
geometries
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.1.5
Component: buildbots | Version: 3.1.x
Resolution: | Keywords:
Description changed by robe:
Old description:
> berrie64 got swapped out with a newer berrie64 and sadly she is hanging
> on her garden test run.
> 00:18:40 PostgreSQL 13.5 on aarch64-unknown-linux-gnu, compiled by gcc
> (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
> 00:18:40 Postgis 3.1.5dev - (77a4e86) - 2021-11-22 05:04:52
> 00:18:40 scripts 3.1.5dev 77a4e86
> 00:18:40 raster scripts 3.1.5dev 77a4e86
> 00:18:40 GEOS: 3.9.0-CAPI-1.16.2
> 00:18:40 PROJ: 7.2.1
> 00:18:40 GDAL: GDAL 3.2.2, released 2021/03/05
> 00:18:40
> 00:26:22 -------------------------------------------------
> 00:26:22 Regression tests in progress (it will take time)
> 00:26:22 Result output: ./regress/postgis_garden_result.txt
> 00:26:22 psql --no-psqlrc -ad postgis_garden <
> ../doc/postgis_gardentest_31.sql > postgis_garden_result.txt 2>&1
> 17:07:08 make[1]: *** [Makefile:100: garden] Error 2
> 17:07:08 make[1]: Leaving directory
> '/home/jenkins/workspace/PostGIS_Worker_Run/label/berrie64/77a4e86e2a22432d6bd56b424d8a48517d91f317/regress'
> 17:07:08 make: *** [GNUmakefile:115: garden] Error 2
> 17:07:08 Build step 'Execute shell' marked build as failure
> I'll update with forensics after I have checked the forensics
New description:
berrie64 got swapped out with a newer berrie64 and sadly she is hanging on
00:18:40
also on PostGIS 3.2 /PG 14
19:53:33 PostgreSQL 14.1 on aarch64-unknown-linux-gnu, compiled by gcc
19:53:33 Postgis 3.2.0dev - (677d201) - 2021-11-21 00:40:23
19:53:33 scripts 3.2.0dev 677d201
19:53:33 raster scripts 3.2.0dev 677d201
19:53:33 GEOS: 3.9.0-CAPI-1.16.2
19:53:33 PROJ: 7.2.1
19:53:33 GDAL: GDAL 3.2.2, released 2021/03/05
20:00:26 -------------------------------------------------
20:00:26 Regression tests in progress (it will take time)
20:00:26 Result output: ./regress/postgis_garden_result.txt
20:00:26 psql --no-psqlrc -ad postgis_garden <
../doc/postgis_gardentest_32.sql > postgis_garden_result.txt 2>&1
22:21:32 make[1]: *** [Makefile:100: garden] Error 2
22:21:32 make[1]: Leaving directory
'/home/jenkins/workspace/PostGIS_Worker_Run/label/berrie64/677d2019a7b7da0f4a6b63eac22dd607ffd72a83/regress'
22:21:32 make: *** [GNUmakefile:115: garden] Error 2
22:21:32 Build step 'Execute shell' marked build as failure
22:21:38 Finished: FAILURE
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5023#comment:5>
