[postgis-tickets] [PostGIS] #5023: berrie64 failing on garden tests ST_MaximumInscribedCircle with malformed geometries
trac at osgeo.org
Tue Nov 23 10:38:03 PST 2021
geometries
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.1.5
Component: buildbots | Version: 3.1.x
Resolution: | Keywords:
Comment (by robe):
Same issue on berrie (32-bit Raspberry Pi arm). So my conclusion is it
must be an ARM / GEOS >= 3.9+. I'm going to check against the GEOS built
by berrie instead of using the system provided (3.9.0) and see if perhaps
it's fixed in newer GEOS. and get a backtrace.
FWIW, it isn't failing. It's going into some sort of infinite loop.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5023#comment:7>
