[postgis-tickets] [PostGIS] #5014: flatgeobuf test failure
PostGIS trac at osgeo.org
Thu Nov 25 11:49:41 PST 2021
  Reporter:  Bas Couwenberg  |      Owner:  pramsey
      Type:  defect          |     Status:  new
  Priority:  blocker         |  Milestone:  PostGIS 3.2.0
 Component:  postgis         |    Version:  master
Resolution:                  |   Keywords:
Comment (by robe):
 I tested with bookworm -  AKA bookkie (which I guess has been promoted to
 testing).  I couldn't replicate the issue there so I suspect something
 else with the cowbuilder setup or the truly sid. Going to try again with a
 true sid.
 This was running with PostgreSQL 14 distribution packaged with bookworm.
 I'm going to go back to the cowbuilder setup I have and see if I can still
 replicate it there.
 If I can't compiling from scratch we might just need to package the beta2
 and have Bas see if he can still replicate.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5014#comment:8>
