[postgis-tickets] [PostGIS] #5001: ST_LocateBetween with offset causes internal error
trac at osgeo.org
Thu Nov 25 11:55:33 PST 2021
Reporter: mdavis | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.1.5
Component: postgis | Version: 3.1.x
Resolution: wontfix | Keywords:
Changes (by pramsey):
* status: new => closed
* resolution: => wontfix
Comment:
This is a sufficiently rare case, and the "fix" is sufficiently unpleasant
(only return part of the offset curve) and there's a workaround (do the
interpolation with 0 offset and then pass the result through the offset
function after) and the next GEOS will include improved and more robust
offsetting that won't have this problem, that... I'm closing as won't fix.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5001#comment:4>
