[postgis-tickets] [PostGIS] #5019: Add support for pcre2
PostGIS trac at osgeo.org
Thu Nov 25 14:55:11 PST 2021
  Reporter:  Bas Couwenberg       |      Owner:  robe
      Type:  enhancement          |     Status:  reopened
  Priority:  medium               |  Milestone:  PostGIS 3.2.0
 Component:  pagc_address_parser  |    Version:  master
Resolution:                       |   Keywords:
Changes (by robe):
 * status:  closed => reopened
 * resolution:  fixed =>
Comment:
 Okay reopening.  Seems debbie is not happy.  I think she only has pcre1
 but she's failing on
 14:26:09 configure: error: Package requirements (libpcre) were not met:
 14:26:09
 14:26:09 No package 'libpcre' found
 14:26:09
 14:26:09 Consider adjusting the PKG_CONFIG_PATH environment variable if
 you
 14:26:09 installed software in a non-standard prefix.
 14:26:09
 Might be something I misconfigured that this change is triggering.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5019#comment:8>
