[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0beta1-46-gfd77a4568
Fri Nov 26 10:50:10 PST 2021
the project "PostGIS".
       via  fd77a456835e7fd95f89ec39b1a4a143fdf617ac (commit)
       via  8a73bd724cbd54ca0050976bcc47d273129b02d3 (commit)
       via  c8dff7949a55f2262b81a620f0203153f8b994cf (commit)
       via  2b7c91f54e3499cddf169e19ba0f2778a50c925f (commit)
      from  98d041b06e3dfcdc9ae71bdd82171254d16d0673 (commit)
revisions in full, below.
commit fd77a456835e7fd95f89ec39b1a4a143fdf617ac
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Fri Nov 26 21:49:44 2021 +0300
    Add NEWS for MVT clipping.
diff --git a/NEWS b/NEWS
index bc24932d9..b8da9a44f 100644
--- a/NEWS
+++ b/NEWS
@@ -16,6 +16,10 @@ Changes since PostGIS 3.2.0beta1 release:
   * Enhancements *
   - #5018, pgsql2shp basic support for WITH CTE clause (Regina Obe)
   - #5019, address_standardizer: Add support for pcre2 (Paul Ramsey)
+  - ST_AsMVTGeom now uses faster clipping (Aliaksandr Kalenik)
+  - ST_PixelAsCentroids, ST_PixelAsCentroid reimplemented in C (Sergei Shoulbakov)
 PostGIS 3.2.0
 2021/xx/xx
@@ -78,6 +82,7 @@ PostGIS 3.2.0
            (Han Wang, Aliaksandr Kalenik, Darafei Praliaskouski, Giuseppe Broccolo)
   - #4949, Use proj_normalize_for_visualization to hand "axis swap" decisions (Paul Ramsey)
   - ST_PixelAsCentroids, ST_PixelAsCentroid reimplemented on top of a C function (Sergei Shoulbakov)
  * New features*
   - #4923, topology.ValidateTopologyRelation (Sandro Santilli)
commit 8a73bd724cbd54ca0050976bcc47d273129b02d3
Merge: 98d041b06 c8dff7949
Date:   Fri Nov 26 21:45:14 2021 +0300
    Merge 'lwgeom_wagyu: replace wagyu's quick_lr_clip with lwgeom_clip_to_ordinate_range'
    Closes https://github.com/postgis/postgis/pull/647
commit c8dff7949a55f2262b81a620f0203153f8b994cf
Merge: b58339cce 2b7c91f54
Author: kalenikaliaksandr <kalenik.aliaksandr at gmail.com>
Date:   Fri Nov 26 21:06:05 2021 +0300
    Merge 2b7c91f54e3499cddf169e19ba0f2778a50c925f into b58339cce2df86cca7d6b5ad97e415836edc9caf
commit 2b7c91f54e3499cddf169e19ba0f2778a50c925f
Author: Aliaksandr Kalenik <kalenik.aliaksandr at gmail.com>
Date:   Mon Nov 22 16:43:55 2021 +0300
diff --git a/deps/wagyu/lwgeom_wagyu.cpp b/deps/wagyu/lwgeom_wagyu.cpp
index b8a682381..a25a0d189 100644
--- a/deps/wagyu/lwgeom_wagyu.cpp
+++ b/deps/wagyu/lwgeom_wagyu.cpp
@@ -26,7 +26,6 @@
 #define USE_WAGYU_INTERRUPT
 #include "mapbox/geometry/wagyu/wagyu.hpp"
-#include "mapbox/geometry/wagyu/quick_clip.hpp"
 #include <iterator>
 #include <limits>
@@ -40,20 +39,13 @@ using wagyu_multipolygon = mapbox::geometry::multi_polygon<wagyu_coord_type>;
 using wagyu_linearring = mapbox::geometry::linear_ring<wagyu_coord_type>;
 using vwpolygon = std::vector<wagyu_polygon>;
 using wagyu_point = mapbox::geometry::point<wagyu_coord_type>;
-using wagyu_box = mapbox::geometry::box<wagyu_coord_type>;
 static wagyu_linearring
-ptarray_to_wglinearring(const POINTARRAY *pa, const wagyu_box &tile)
+ptarray_to_wglinearring(const POINTARRAY *pa)
 	wagyu_linearring lr;
 	lr.reserve(pa->npoints);
-	/* We calculate the bounding box of the point array */
-	wagyu_coord_type min_x = std::numeric_limits<wagyu_coord_type>::max();
-	wagyu_coord_type max_x = std::numeric_limits<wagyu_coord_type>::min();
-	wagyu_coord_type min_y = min_x;
-	wagyu_coord_type max_y = max_x;
 	size_t point_size = ptarray_point_size(pa);
 	size_t pa_size = pa->npoints;
 	uint8_t *buffer = pa->serialized_pointlist;
@@ -62,62 +54,48 @@ ptarray_to_wglinearring(const POINTARRAY *pa, const wagyu_box &tile)
 		const wagyu_coord_type x = static_cast<wagyu_coord_type>(*(double*) buffer);
 		const wagyu_coord_type y = static_cast<wagyu_coord_type>(((double*) buffer)[1]);
 		buffer += point_size;
-		min_x = std::min(min_x, x);
-		max_x = std::max(max_x, x);
-		min_y = std::min(min_y, y);
-		max_y = std::max(max_y, y);
 		lr.emplace_back(static_cast<wagyu_coord_type>(x), static_cast<wagyu_coord_type>(y));
-	/* Check how many sides of the calculated box are inside the tile */
-	uint32_t sides_in = 0;
-	sides_in += min_x >= tile.min.x && min_x <= tile.max.x;
-	sides_in += max_x >= tile.min.x && max_x <= tile.max.x;
-	sides_in += min_y >= tile.min.y && min_y <= tile.max.y;
-	sides_in += max_y >= tile.min.y && max_y <= tile.max.y;
-	/* With 0 sides in, the box it's either outside or covers the tile completely */
-	if ((sides_in == 0) && (min_x > tile.max.x || max_x < tile.min.x || min_y > tile.max.y || max_y < tile.min.y))
-		/* No overlapping: Return an empty linearring */
-		return wagyu_linearring();
-	if (sides_in != 4)
-		/* Some edges need to be clipped */
-		return mapbox::geometry::wagyu::quick_clip::quick_lr_clip(lr, tile);
-	/* All points are inside the box */
 	return lr;
 static vwpolygon
-lwpoly_to_vwgpoly(const LWPOLY *geom, const wagyu_box &box)
+lwpoly_to_vwgpoly(const LWPOLY *geom, const GBOX *box)
+	LWCOLLECTION *geom_clipped_x = lwgeom_clip_to_ordinate_range((LWGEOM *)geom, 'X', box->xmin, box->xmax, 0);
+	LWCOLLECTION *geom_clipped = lwgeom_clip_to_ordinate_range((LWGEOM *)geom_clipped_x, 'Y', box->ymin, box->ymax, 0);
 	vwpolygon vp;
-	for (std::uint32_t i = 0; i < geom->nrings; i++)
+	for (std::uint32_t i = 0; i < geom_clipped->ngeoms; i++)
-		wagyu_polygon pol;
-		pol.push_back(ptarray_to_wglinearring(geom->rings[i], box));
-		/* If it has an inner ring, push it too */
-		i++;
-		if (i != geom->nrings)
+		assert(geom_clipped->geoms[i]->type == POLYGONTYPE);
+		LWPOLY *poly = (LWPOLY *)geom_clipped->geoms[i];
+		for (std::uint32_t ring = 0; ring < poly->nrings; ring++)
+			wagyu_polygon pol;
+			pol.push_back(ptarray_to_wglinearring(poly->rings[ring]));
+			/* If it has an inner ring, push it too */
+			ring++;
+			if (ring != poly->nrings)
-		vp.push_back(pol);
+			vp.push_back(pol);
+	lwgeom_free((LWGEOM *)geom_clipped_x);
+	lwgeom_free((LWGEOM *)geom_clipped);
 	return vp;
 static vwpolygon
-lwmpoly_to_vwgpoly(const LWMPOLY *geom, const wagyu_box &box)
+lwmpoly_to_vwgpoly(const LWMPOLY *geom, const GBOX *box)
 	vwpolygon vp;
 	for (std::uint32_t i = 0; i < geom->ngeoms; i++)
@@ -139,7 +117,7 @@ lwmpoly_to_vwgpoly(const LWMPOLY *geom, const wagyu_box &box)
  * previous rings)
 static vwpolygon
-lwgeom_to_vwgpoly(const LWGEOM *geom, const wagyu_box &box)
+lwgeom_to_vwgpoly(const LWGEOM *geom, const GBOX *box)
 	switch (geom->type)
@@ -227,12 +205,8 @@ __lwgeom_wagyu_clip_by_box(const LWGEOM *geom, const GBOX *bbox)
 		return out;
-	wagyu_point box_min(std::min(bbox->xmin, bbox->xmax), std::min(bbox->ymin, bbox->ymax));
-	wagyu_point box_max(std::max(bbox->xmin, bbox->xmax), std::max(bbox->ymin, bbox->ymax));
-	const wagyu_box box(box_min, box_max);
 	wagyu_multipolygon solution;
-	vwpolygon vpsubject = lwgeom_to_vwgpoly(geom, box);
+	vwpolygon vpsubject = lwgeom_to_vwgpoly(geom, bbox);
 	if (vpsubject.size() == 0)
 		LWGEOM *out = lwgeom_construct_empty(MULTIPOLYGONTYPE, geom->srid, 0, 0);
diff --git a/regress/core/mvt.sql b/regress/core/mvt.sql
index a4c29e460..f52d9e3b2 100644
--- a/regress/core/mvt.sql
+++ b/regress/core/mvt.sql
@@ -371,7 +371,7 @@ WITH geometry AS
 	100, 0, true))) as g
 SELECT 'PG57',
-        g = 'POLYGON((0 1,0 100,100 100,100 0,1 0,0 1))' OR g = 'POLYGON((0 0,0 1,0 100,100 100,100 0,0 0))'
+        g = 'POLYGON((0 1,0 100,100 100,100 0,1 0,0 1))' OR g = 'POLYGON((0 0,0 1,0 100,100 100,100 0,0 0))' OR g = 'POLYGON((0 0,0 100,100 100,100 0,0 0))'
 FROM geometry;
 -- Geometrycollection test
diff --git a/regress/core/mvt_expected b/regress/core/mvt_expected
index 9b6e5c130..6e72b2be1 100644
--- a/regress/core/mvt_expected
+++ b/regress/core/mvt_expected
@@ -52,7 +52,7 @@ PG42 - OFF|LINESTRING(0 10,0 0,1 0)
 PG43 - ON |MULTIPOLYGON(((0 10,10 10,5 5,0 10)),((0 0,5 5,10 0,0 0)))
 PG43 - OFF|MULTIPOLYGON(((5 5,-1 -1,11 -1,5 5)),((5 5,11 11,-1 11,5 5)))
 PG44|
-PG45|
+PG45|SRID=3857;POLYGON((2803 34,2796 -16,2797 -16,2803 34))
 PG46|SRID=3857;POLYGON((3262 2030,3253 2158,3245 2224,3262 2030))
 PG47|
 PG48|
Summary of changes:
 NEWS                        |  5 +++
 deps/wagyu/lwgeom_wagyu.cpp | 78 +++++++++++++++------------------------------
 regress/core/mvt.sql        |  2 +-
 regress/core/mvt_expected   |  2 +-
 4 files changed, 33 insertions(+), 54 deletions(-)
hooks/post-receive
