[postgis-tickets] [PostGIS] #5014: flatgeobuf test failure
trac at osgeo.org
Fri Nov 26 23:28:07 PST 2021
Reporter: Bas Couwenberg | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 3.2.0
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by Bas Couwenberg):
Still fails with beta2.
The backtrace posted earlier shows:
memcpy ([...]) at /usr/include/x86_64-linux-gnu/bits/string_fortified.h:29
This suggest hardening flags may be the reason you cannot reproduce the
issue when not using `dpkg-buildpackage`. The flags it uses are:
# DEB_BUILD_MAINT_OPTIONS=hardening=+all dpkg-buildflags --export=sh
export CFLAGS="-g -O2 -ffile-prefix-map=/build/postgis=. -fstack-
protector-strong -Wformat -Werror=format-security"
export CPPFLAGS="-Wdate-time -D_FORTIFY_SOURCE=2"
export CXXFLAGS="-g -O2 -ffile-prefix-map=/build/postgis=. -fstack-
export DFLAGS="-frelease"
export FCFLAGS="-g -O2 -ffile-prefix-map=/build/postgis=. -fstack-
protector-strong"
export FFLAGS="-g -O2 -ffile-prefix-map=/build/postgis=. -fstack-
protector-strong"
export GCJFLAGS="-g -O2 -ffile-prefix-map=/build/postgis=. -fstack-
protector-strong"
export LDFLAGS="-Wl,-z,relro -Wl,-z,now"
export OBJCFLAGS="-g -O2 -ffile-prefix-map=/build/postgis=. -fstack-
export OBJCXXFLAGS="-g -O2 -ffile-prefix-map=/build/postgis=. -fstack-
[https://lwn.net/Articles/584225/ -fstack-protector-strong] might be it.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5014#comment:15>
