[postgis-tickets] [PostGIS] #5014: flatgeobuf test failure
PostGIS trac at osgeo.org
Sat Nov 27 03:54:47 PST 2021
  Reporter:  Bas Couwenberg  |      Owner:  pramsey
      Type:  defect          |     Status:  new
  Priority:  critical        |  Milestone:  PostGIS 3.2.0
 Component:  postgis         |    Version:  master
Resolution:                  |   Keywords:
Comment (by Bas Couwenberg):
 Disabling the `P5` & `P6` tests makes the testsuite not fail, enabling
 either of those two tests causes the testsuite to fail.
 Is the flatgeobuf code valgrind clean? The `memcpy` call from the
 backtrace might point to memory issues.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5014#comment:16>
