[postgis-tickets] [PostGIS] #5014: flatgeobuf test failure
trac at osgeo.org
Sat Nov 27 05:17:43 PST 2021
Reporter: Bas Couwenberg | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 3.2.0
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by Björn Harrtell):
Inspected the code and the trace above and it is strange.... it seems to
crash on a memcpy that is triggered by flatgeobuf_encode_header and
CreateHeaderDirect. This is code run on several other occations including
in the non-indexed variants. But, it also says the invocations follow
flatgeobuf_create_index which is the second time it's called in that
execution of ST_AsFlatGeobuf so I suppose it must mean it is not safe to
call multiple times - but I cannot understand why yet.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5014#comment:18>
