[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0beta2-5-gd71751919
git at osgeo.org
git at osgeo.org
Sat Nov 27 13:47:27 PST 2021
the project "PostGIS".
via d71751919c84ae83fa32268197caced462154ab2 (commit)
via 1d175e47ab884e6b543c014e16297b434f462006 (commit)
from eda70258f373c1ad88e1851f194c891ad8d9aff4 (commit)
revisions in full, below.
commit d71751919c84ae83fa32268197caced462154ab2
Merge: eda70258f 1d175e47a
Author: bjornharrtell <bjorn at wololo.org>
Date: Sat Nov 27 13:47:27 2021 -0800
Merge pull request 'Catch and bail on mixed geometry type' (!64) from bjornharrtell/postgis:issue-5028 into master
Reviewed-on: https://git.osgeo.org/gitea/postgis/postgis/pulls/64
commit 1d175e47ab884e6b543c014e16297b434f462006
Author: Björn Harrtell <bjorn at wololo.org>
Date: Sat Nov 27 22:43:42 2021 +0100
diff --git a/deps/flatgeobuf/flatgeobuf_c.cpp b/deps/flatgeobuf/flatgeobuf_c.cpp
index 2ef2dd401..7c61534a2 100644
--- a/deps/flatgeobuf/flatgeobuf_c.cpp
+++ b/deps/flatgeobuf/flatgeobuf_c.cpp
@@ -35,7 +35,6 @@ typedef flatgeobuf_ctx ctx;
uint8_t flatgeobuf_magicbytes[] = { 0x66, 0x67, 0x62, 0x03, 0x66, 0x67, 0x62, 0x01 };
uint8_t FLATGEOBUF_MAGICBYTES_SIZE = sizeof(flatgeobuf_magicbytes);
-uint8_t FLATGEOBUF_MAGICBYTES_LEN = (sizeof(flatgeobuf_magicbytes) / sizeof((flatgeobuf_magicbytes)[0]));
struct FeatureItem : FlatGeobuf::Item {
uoffset_t size;
@@ -53,6 +52,7 @@ int flatgeobuf_encode_header(ctx *ctx)
ctx->srid = ctx->lwgeom->srid;
ctx->has_z = lwgeom_has_z(ctx->lwgeom);
ctx->has_m = lwgeom_has_m(ctx->lwgeom);
+ ctx->lwgeom_type = ctx->lwgeom->type;
ctx->geometry_type = (uint8_t) GeometryWriter::get_geometrytype(ctx->lwgeom);
} else {
LWDEBUG(2, "ctx->lwgeom is null");
@@ -121,6 +121,10 @@ int flatgeobuf_encode_feature(ctx *ctx)
if (ctx->lwgeom != NULL && !lwgeom_is_empty(ctx->lwgeom)) {
LWDEBUGG(3, ctx->lwgeom, "GeometryWriter input LWGEOM");
+ if (ctx->lwgeom_type != ctx->lwgeom->type) {
+ lwerror("mixed geometry type is not supported");
+ return -1;
GeometryWriter writer(fbb, ctx->lwgeom, (GeometryType) ctx->geometry_type, ctx->has_z, ctx->has_m);
geometry = writer.write(0);
@@ -192,19 +196,19 @@ void flatgeobuf_create_index(ctx *ctx)
// allocate new buffer and write magicbytes
auto oldbuf = ctx->buf;
auto oldoffset = ctx->offset;
- ctx->buf = (uint8_t *) lwalloc(sizeof(signed int) + sizeof(flatgeobuf_magicbytes));
- memcpy(ctx->buf + sizeof(signed int), flatgeobuf_magicbytes, sizeof(flatgeobuf_magicbytes));
- ctx->offset = sizeof(signed int) + sizeof(flatgeobuf_magicbytes);
+ ctx->buf = (uint8_t *) lwalloc(sizeof(signed int) + FLATGEOBUF_MAGICBYTES_SIZE);
+ memcpy(ctx->buf + sizeof(signed int), flatgeobuf_magicbytes, FLATGEOBUF_MAGICBYTES_SIZE);
+ ctx->offset = sizeof(signed int) + FLATGEOBUF_MAGICBYTES_SIZE;
// write new header
flatgeobuf_encode_header(ctx);
// create and write index
+ PackedRTree tree(items, extent, ctx->index_node_size);
const auto writeData = [&ctx] (const void *data, const size_t size) {
ctx->buf = (uint8_t *) lwrealloc(ctx->buf, ctx->offset + size);
memcpy(ctx->buf + ctx->offset, data, size);
+ ctx->offset += size;
- PackedRTree tree(items, extent, ctx->index_node_size);
tree.streamWrite(writeData);
- ctx->offset += tree.size();
// read items and write in sorted order
for (auto item : items) {
auto featureItem = std::static_pointer_cast<FeatureItem>(item);
@@ -235,13 +239,6 @@ int flatgeobuf_decode_feature(ctx *ctx)
const auto geometry = feature->geometry();
if (geometry != nullptr) {
- if (geometry->ends() != nullptr) {
- LWDEBUGF(3, "ENDS: %d", geometry->ends()->size());
- for (uint32_t i = 0; i < geometry->ends()->size(); i++) {
- LWDEBUGF(3, "ENDS: %d", geometry->ends()->Get(i));
LWDEBUGF(3, "Constructing GeometryReader with geometry_type %d has_z %d haz_m %d", ctx->geometry_type, ctx->has_z, ctx->has_m);
GeometryReader reader(geometry, (GeometryType) ctx->geometry_type, ctx->has_z, ctx->has_m);
ctx->lwgeom = reader.read();
diff --git a/deps/flatgeobuf/flatgeobuf_c.h b/deps/flatgeobuf/flatgeobuf_c.h
index 8ba401ddb..b5ea062bf 100644
--- a/deps/flatgeobuf/flatgeobuf_c.h
+++ b/deps/flatgeobuf/flatgeobuf_c.h
@@ -34,7 +34,6 @@ extern "C" {
extern uint8_t flatgeobuf_magicbytes[];
extern uint8_t FLATGEOBUF_MAGICBYTES_SIZE;
-extern uint8_t FLATGEOBUF_MAGICBYTES_LEN;
// need c compatible variant of this enum
#define flatgeobuf_column_type_byte UINT8_C(0)
@@ -104,6 +103,7 @@ typedef struct flatgeobuf_ctx
uint64_t size;
LWGEOM *lwgeom;
+ uint8_t lwgeom_type;
uint8_t *properties;
uint32_t properties_len;
uint32_t properties_size;
diff --git a/postgis/flatgeobuf.c b/postgis/flatgeobuf.c
index 566e6cdca..1b502e546 100644
--- a/postgis/flatgeobuf.c
+++ b/postgis/flatgeobuf.c
@@ -268,10 +268,10 @@ void flatgeobuf_check_magicbytes(struct flatgeobuf_decode_ctx *ctx)
uint8_t *buf = ctx->ctx->buf + ctx->ctx->offset;
uint32_t i;
- for (i = 0; i < FLATGEOBUF_MAGICBYTES_LEN / 2; i++)
+ for (i = 0; i < FLATGEOBUF_MAGICBYTES_SIZE / 2; i++)
if (buf[i] != flatgeobuf_magicbytes[i])
elog(ERROR, "Data is not FlatGeobuf");
- ctx->ctx->offset += FLATGEOBUF_MAGICBYTES_LEN;
+ ctx->ctx->offset += FLATGEOBUF_MAGICBYTES_SIZE;
static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values, bool *isnull)
diff --git a/regress/core/flatgeobuf.sql b/regress/core/flatgeobuf.sql
index 15df3aaab..c2e9167e7 100644
--- a/regress/core/flatgeobuf.sql
+++ b/regress/core/flatgeobuf.sql
@@ -104,6 +104,15 @@ select 'P1', id, ST_AsText(geom) from ST_FromFlatGeobuf(null::flatgeobuf_t1, (
) q)
+-- Multiple 2D points and a polygon
+select 'PL1', id, ST_AsText(geom) from ST_FromFlatGeobuf(null::flatgeobuf_t1, (
+ select ST_AsFlatGeobuf(q) from (values
+ ('POINT (1 2)'::geometry),
+ ('POINT (3 4)'::geometry),
+ ('POLYGON ((35 10, 45 45, 15 40, 10 20, 35 10), (20 30, 35 35, 30 20, 20 30))'::geometry)
+ ) q)
select '--- Attribute roundtrips ---';
select ST_TableFromFlatGeobuf('public', 'flatgeobuf_a1', (select ST_AsFlatGeobuf(q) fgb from (select
diff --git a/regress/core/flatgeobuf_expected b/regress/core/flatgeobuf_expected
index bb17110b6..60f3ab847 100644
--- a/regress/core/flatgeobuf_expected
+++ b/regress/core/flatgeobuf_expected
@@ -19,6 +19,7 @@ GC1|0|GEOMETRYCOLLECTION(POINT(40 10),LINESTRING(10 10,20 20,10 40),POLYGON((40
--- Multiple rows ---
P1|0|POINT(1 2)
P1|1|POINT(3 4)
+ERROR: mixed geometry type is not supported
A1|0||t|1|2|3|4|1.2|1.3|2016-06-23 03:44:52.134125+00|hello
--- Exotic roundtrips ---
Summary of changes:
deps/flatgeobuf/flatgeobuf_c.cpp | 23 ++++++++++-------------
deps/flatgeobuf/flatgeobuf_c.h | 2 +-
postgis/flatgeobuf.c | 4 ++--
regress/core/flatgeobuf.sql | 9 +++++++++
regress/core/flatgeobuf_expected | 1 +
5 files changed, 23 insertions(+), 16 deletions(-)
hooks/post-receive
