[postgis-tickets] [PostGIS] #5030: PostGis 3.1.4 fails to test (mvt) successfully on ppc64el in Ubuntu 22.04
PostGIS trac at osgeo.org
Mon Nov 29 07:56:46 PST 2021
 Reporter:  cpaelzer  |      Owner:  pramsey
     Type:  defect    |     Status:  new
 Priority:  medium    |  Milestone:  PostGIS 3.1.5
Component:  postgis   |    Version:  3.1.x
 Keywords:            |
 As reported in Ubuntu [1] and today on IRC we have trouble building
 postgis 3.1.4 on Ubuntu right now. What I see is an issue in mvt:
 ./regress/core/mvt .. failed (diff expected obtained:
 /tmp/pgis_reg/test_110_diff)
 --- ./regress/core/mvt_expected 2021-09-04 05:03:43.000000000 +0000
 +++ /tmp/pgis_reg/test_110_out 2021-11-20 06:56:10.856917815 +0000
 @@ -138,7 +138,7 @@
  #4348Clip|t
  #4348Invalid|t
  #4348Dropped|t
 -#4348ReversedSmall|t
 +#4348ReversedSmall|
  #4348Reversed2|t
  #4348Point|t
  #4348Crash|t
 Earlier this year 3.1.1 built fine [5] in Ubuntu.
 So did 3.1.4 in Debian in January of this year [6].
 I fail to see/understand what is broken here and was hoping that you could
 make sense of it.
 I failed to recreate the issue on a ppc64el machine. With the same SW
 versions of build dependencies installed I got it working:
    ./regress/core/mvt .. ok in 279 ms
 But OTOH in the launchpad build environment [2][3] it is 100%
 reproducible.
 The Debian build already ignores test issues on many non-x86 platforms and
 I guess for now I'll need to add ppc64el to that list.
 But if mid-term there would be a real fix that would be great.
 In the log [4] you'll also find the postgresql server errors, but usually
 - since some tests trigger errors intentionally - those logs are not very
 helpful.
 Thanks in advance.
 I'd even be happy to get hints at what might affect this, is it very
 sensible to lib versions, memory or cores available at run time or
 anything else that could be different from the official Ubuntu build
 environment and my try to recreate? What would usually affect this bug?
 [1]: https://bugs.launchpad.net/ubuntu/+source/postgis/+bug/1952604
 [2]: https://launchpad.net/ubuntu/+source/postgis/3.1.4+dfsg-3build1
 [3]: https://launchpad.net/ubuntu/+source/postgis/3.1.4+dfsg-
 3build1/+build/22346629
 [4]: https://launchpadlibrarian.net/571347323/buildlog_ubuntu-jammy-
 ppc64el.postgis_3.1.4+dfsg-3build1_BUILDING.txt.gz
 [5]: https://launchpad.net/ubuntu/+source/postgis/3.1.1+dfsg-1
 [6]:
 https://buildd.debian.org/status/fetch.php?pkg=postgis&arch=ppc64el&ver=3.1.4%2Bdfsg-3%2Bb1&stamp=1634938635&raw=0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5030>
