[postgis-tickets] [PostGIS] #5123: PostgreSQL 15 build is broken - jsonb failures
trac at osgeo.org
Fri Apr 1 10:04:54 PDT 2022
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.3.0
Component: postgis | Version: 3.2.x
Keywords: |
I assume this is the result of the new json features that landed in
PostgreSQL 15 recently.
Debbie is unhappy.
19:43:46 38 | JSONTYPE_NULL, /* null, so we didn't bother to
identify */
19:43:46 | ^~~~~~~~~~~~~
19:43:46 In file included from lwgeom_out_geojson.c:21:
19:43:46
/var/lib/jenkins/workspace/pg/rel/pg15w64/include/postgresql/server/utils/json.h:21:2:
note: previous definition of ‘JSONTYPE_NULL’ was here
19:43:46 21 | JSONTYPE_NULL, /* null, so we didn't bother to
identify */
19:43:46 lwgeom_out_geojson.c:39:2: error: redeclaration of enumerator
‘JSONTYPE_BOOL’
19:43:46 39 | JSONTYPE_BOOL, /* boolean (built-in types only) */
19:43:46
/var/lib/jenkins/workspace/pg/rel/pg15w64/include/postgresql/server/utils/json.h:22:2:
note: previous definition of ‘JSONTYPE_BOOL’ was here
19:43:46 22 | JSONTYPE_BOOL, /* boolean (built-in types only) */
19:43:46 lwgeom_out_geojson.c:40:2: error: redeclaration of enumerator
‘JSONTYPE_NUMERIC’
19:43:46 40 | JSONTYPE_NUMERIC, /* numeric (ditto) */
19:43:46 | ^~~~~~~~~~~~~~~~
19:43:46
/var/lib/jenkins/workspace/pg/rel/pg15w64/include/postgresql/server/utils/json.h:23:2:
note: previous definition of ‘JSONTYPE_NUMERIC’ was here
19:43:46 23 | JSONTYPE_NUMERIC, /* numeric (ditto) */
19:43:46 lwgeom_out_geojson.c:41:2: error: redeclaration of enumerator
‘JSONTYPE_DATE’
19:43:46 41 | JSONTYPE_DATE, /* we use special formatting for
datetimes */
19:43:46
/var/lib/jenkins/workspace/pg/rel/pg15w64/include/postgresql/server/utils/json.h:24:2:
note: previous definition of ‘JSONTYPE_DATE’ was here
19:43:46 24 | JSONTYPE_DATE, /* we use special formatting for
datetimes */
19:43:46 lwgeom_out_geojson.c:42:2: error: redeclaration of enumerator
‘JSONTYPE_TIMESTAMP’
19:43:46 42 | JSONTYPE_TIMESTAMP,
19:43:46 | ^~~~~~~~~~~~~~~~~~
19:43:46
/var/lib/jenkins/workspace/pg/rel/pg15w64/include/postgresql/server/utils/json.h:25:2:
note: previous definition of ‘JSONTYPE_TIMESTAMP’ was here
19:43:46 25 | JSONTYPE_TIMESTAMP,
19:43:46 lwgeom_out_geojson.c:43:2: error: redeclaration of enumerator
‘JSONTYPE_TIMESTAMPTZ’
19:43:46 43 | JSONTYPE_TIMESTAMPTZ,
19:43:46 | ^~~~~~~~~~~~~~~~~~~~
19:43:46
/var/lib/jenkins/workspace/pg/rel/pg15w64/include/postgresql/server/utils/json.h:26:2:
note: previous definition of ‘JSONTYPE_TIMESTAMPTZ’ was here
19:43:46 26 | JSONTYPE_TIMESTAMPTZ,
19:43:46 lwgeom_out_geojson.c:44:2: error: redeclaration of enumerator
‘JSONTYPE_JSON’
19:43:46 44 | JSONTYPE_JSON, /* JSON itself (and JSONB) */
19:43:46
/var/lib/jenkins/workspace/pg/rel/pg15w64/include/postgresql/server/utils/json.h:27:2:
note: previous definition of ‘JSONTYPE_JSON’ was here
19:43:46 27 | JSONTYPE_JSON, /* JSON itself (and JSONB) */
19:43:46 lwgeom_out_geojson.c:45:2: error: redeclaration of enumerator
‘JSONTYPE_ARRAY’
19:43:46 45 | JSONTYPE_ARRAY, /* array */
19:43:46
/var/lib/jenkins/workspace/pg/rel/pg15w64/include/postgresql/server/utils/json.h:28:2:
note: previous definition of ‘JSONTYPE_ARRAY’ was here
19:43:46 28 | JSONTYPE_ARRAY, /* array */
19:43:46 lwgeom_out_geojson.c:46:2: error: redeclaration of enumerator
‘JSONTYPE_COMPOSITE’
19:43:46 46 | JSONTYPE_COMPOSITE, /* composite */
19:43:46
/var/lib/jenkins/workspace/pg/rel/pg15w64/include/postgresql/server/utils/json.h:29:2:
note: previous definition of ‘JSONTYPE_COMPOSITE’ was here
19:43:46 29 | JSONTYPE_COMPOSITE, /* composite */
19:43:46 lwgeom_out_geojson.c:47:2: error: redeclaration of enumerator
‘JSONTYPE_CAST’
19:43:46 47 | JSONTYPE_CAST, /* something with an explicit cast to
JSON */
19:43:46
/var/lib/jenkins/workspace/pg/rel/pg15w64/include/postgresql/server/utils/json.h:30:2:
note: previous definition of ‘JSONTYPE_CAST’ was here
19:43:46 30 | JSONTYPE_CAST, /* something with an explicit cast to
JSON */
19:43:46 lwgeom_out_geojson.c:48:2: error: redeclaration of enumerator
‘JSONTYPE_OTHER’
19:43:46 48 | JSONTYPE_OTHER /* all else */
19:43:46
/var/lib/jenkins/workspace/pg/rel/pg15w64/include/postgresql/server/utils/json.h:31:2:
note: previous definition of ‘JSONTYPE_OTHER’ was here
19:43:46 31 | JSONTYPE_OTHER /* all else */
19:43:46 lwgeom_out_geojson.c:49:3: error: conflicting types for
‘JsonTypeCategory’
19:43:46 49 | } JsonTypeCategory;
19:43:46
/var/lib/jenkins/workspace/pg/rel/pg15w64/include/postgresql/server/utils/json.h:32:3:
note: previous declaration of ‘JsonTypeCategory’ was here
19:43:46 32 | } JsonTypeCategory;
19:43:46 lwgeom_out_geojson.c:70:13: error: conflicting types for
‘json_categorize_type’
19:43:46 70 | static void json_categorize_type(Oid typoid,
19:43:46
/var/lib/jenkins/workspace/pg/rel/pg15w64/include/postgresql/server/utils/json.h:39:13:
note: previous declaration of ‘json_categorize_type’ was here
19:43:46 39 | extern void json_categorize_type(Oid typoid,
JsonTypeCategory *tcategory,
19:43:46 make[1]: *** [<builtin>: lwgeom_out_geojson.o] Error 1
19:43:46 make[1]: Leaving directory
'/var/lib/jenkins/workspace/postgis/branches/3.3/postgis'
19:43:46 make: *** [GNUmakefile:24: all] Error 1
19:43:46 Build step 'Execute shell' marked build as failure
I think the failures were introduced by I assume the SQL JSON one that was
part of this run
https://git.postgresql.org/gitweb/?p=postgresql.git;a=commit;h=606948b058dc16bce494270eea577011a602810e
Changes
Fix possible NULL-pointer-deference in backup_compression.c. (details)
SQL JSON functions (details) 606948b058dc16bce494270eea577011a602810e
Optimize order of GROUP BY keys (details)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5123>
