[postgis-tickets] [PostGIS] #5122: Crash on aurora postgres topology add_polygon
trac at osgeo.org
Fri Apr 15 15:48:41 PDT 2022
Reporter: robe | Owner: robe
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 3.1.6
Component: topology | Version: 3.1.x
Resolution: | Keywords:
Description changed by robe:
Old description:
> The performance suite is failing on aurora postgres in a couple of cases.
> In the topology case it crashes
> https://git.osgeo.org/gitea/postgis/postgis-performance
> POSTGIS="3.1.5 0" [EXTENSION] PGSQL="130" GEOS="3.9.1dev-CAPI-1.14.1"
> PROJ="6.2.1" LIBXML="2.9.9" LIBJSON="0.12.99" LIBPROTOBUF="1.3.0"
> WAGYU="0.5.0 (Internal)"
> [02:59:23] pgtap/topology/add_polygon.sql .......
> 1..3
> 16
> psql:pgtap/topology/add_polygon.sql:13: server closed the connection
> unexpectedly
> This probably means the server terminated abnormally
> before or while processing the request.
> psql:pgtap/topology/add_polygon.sql:13: fatal: connection to server was
> lost
> Dubious, test returned 2 (wstat 512, 0x200)
> Failed 3/3 subtests
> The add_linestring was okay except for exceeding time limits
> data
> CREATE EXTENSION postgis_tiger_geocoder CASCADE;
> Load data with psql from Where state boundaries are the ones in -
> http://postgis.net/extra/test-data/tiger_national.sql.bz2
> Test
> SELECT topology.CreateTopology('topoperf', 4269) ;
> CREATE TABLE topoperf.polygon
> AS SELECT (ST_Dump(geom)).geom AS g FROM (SELECT the_geom AS geom FROM
> tiger.state) AS f;
> SELECT topology.TopoGeo_addPolygon('topoperf', g)
> FROM topoperf.polygon;
> I tested on RDS running and that passed fine including the timing
> POSTGIS="3.1.4 ded6c34" [EXTENSION] PGSQL="140" GEOS="3.9.1-CAPI-1.14.2"
> PROJ="8.0.1" LIBXML="2.9.1" LIBJSON="0.15" LIBPROTOBUF="1.3.2"
> WAGYU="0.5.0 (Internal)" TOPOLOGY
> I'm going to isolate further and check other systems.
New description:
1..3
16
unexpectedly
lost
Failed 3/3 subtests
data
CREATE EXTENSION topology;
Test
tiger.state) AS f;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5122#comment:3>
