[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-778-gcf6aebcab
Thu Apr 28 12:15:25 PDT 2022
the project "PostGIS".
       via  cf6aebcab8067ff2e4853f3d9730389f639c3b24 (commit)
      from  78926de5621eccdd9ddc80575d9791d5a27b3c67 (commit)
revisions in full, below.
commit cf6aebcab8067ff2e4853f3d9730389f639c3b24
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Thu Apr 28 12:15:21 2022 -0700
    Improve doc for ST_RemoveRepeatedPoints
diff --git a/doc/reference_editor.xml b/doc/reference_editor.xml
index 4bd632565..a9171aa40 100644
--- a/doc/reference_editor.xml
+++ b/doc/reference_editor.xml
@@ -1528,8 +1528,8 @@ UPDATE sometable
     <refentry id="ST_RemoveRepeatedPoints">
       <refnamediv>
         <refname>ST_RemoveRepeatedPoints</refname>
-        <refpurpose>Returns a version of the given geometry with
-                duplicated points removed.</refpurpose>
+        <refpurpose>Returns a version of a geometry with
+                duplicate points removed.</refpurpose>
       </refnamediv>
       <refsynopsisdiv>
@@ -1544,14 +1544,15 @@ UPDATE sometable
       <refsection>
         <title>Description</title>
-        <para>Returns a version of the given geometry with
-                duplicated points removed. Will actually do something only with
-                (multi)lines, (multi)polygons and multipoints but you can safely call it with
-                any kind of geometry. Since simplification occurs on a
-                object-by-object basis you can also feed a GeometryCollection to
-                this function.</para>
-        <para>If the tolerance parameter is provided, vertices within the tolerance
-        of one another will be considered the "same" for the purposes of removal.</para>
+        <para>Returns a version of the given geometry with duplicate consecutive points removed.
+                The function processes only (Multi)LineStrings, (Multi)Polygons and MultiPoints
+                but it can be called with any kind of geometry.
+                Elements of GeometryCollections are processed individually.
+                The endpoints of LineStrings are preserved.
+        </para>
+        <para>If the <parameter>tolerance</parameter> parameter is provided, vertices within the tolerance distance
+        of one another are considered to be duplicates.</para>
         <para>Enhanced: 3.2.0</para>
         <para>Availability: 2.2.0</para>
@@ -1559,6 +1560,41 @@ UPDATE sometable
         <para>&Z_support;</para>
       </refsection>
+	  <refsection>
+		<title>Examples</title>
+		<programlisting>
+SELECT ST_AsText( ST_RemoveRepeatedPoints( 'MULTIPOINT ((1 1), (2 2), (3 3), (2 2))'));
+ MULTIPOINT(1 1,2 2,3 3)
+</programlisting>
+		<programlisting>
+SELECT ST_AsText( ST_RemoveRepeatedPoints( 'LINESTRING (0 0, 0 0, 1 1, 0 0, 1 1, 2 2)'));
+ LINESTRING(0 0,1 1,0 0,1 1,2 2)
+</programlisting>
+      <para><emphasis role="bold">Example:</emphasis>
+      Collection elements are processed individually.
+      </para>
+		<programlisting>
+SELECT ST_AsText( ST_RemoveRepeatedPoints( 'GEOMETRYCOLLECTION (LINESTRING (1 1, 2 2, 2 2, 3 3), POINT (4 4), POINT (4 4), POINT (5 5))'));
+ GEOMETRYCOLLECTION(LINESTRING(1 1,2 2,3 3),POINT(4 4),POINT(4 4),POINT(5 5))
+</programlisting>
+      Repeated point removal with a distance tolerance.
+      </para>
+		<programlisting>
+SELECT ST_AsText( ST_RemoveRepeatedPoints( 'LINESTRING (0 0, 0 0, 1 1, 5 5, 1 1, 2 2)', 2));
+ LINESTRING(0 0,5 5,2 2)
+</programlisting>
+	  </refsection>
           <refsection>
             <title>See Also</title>
             <para><xref linkend="ST_Simplify" /></para>
Summary of changes:
 doc/reference_editor.xml | 56 +++++++++++++++++++++++++++++++++++++++---------
 1 file changed, 46 insertions(+), 10 deletions(-)
hooks/post-receive
