[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-779-g781a40f92
Thu Apr 28 12:20:32 PDT 2022
the project "PostGIS".
       via  781a40f92ffce904272f2e50f7911b0a4af95969 (commit)
      from  cf6aebcab8067ff2e4853f3d9730389f639c3b24 (commit)
revisions in full, below.
commit 781a40f92ffce904272f2e50f7911b0a4af95969
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Thu Apr 28 12:20:28 2022 -0700
    Improve doc for ST_Points
diff --git a/doc/reference_accessor.xml b/doc/reference_accessor.xml
index ae1c44633..1afa6a48f 100644
--- a/doc/reference_accessor.xml
+++ b/doc/reference_accessor.xml
@@ -2680,11 +2680,11 @@ FROM ST_GeomFromText('LINESTRING(0 0 0, 1 1 1, 2 2 2)') AS g
 			<title>Description</title>
 			<para>
-				Returns a MultiPoint containing all the coordinates of a
-				geometry.  Does not remove points that are repeated in
-				the geometry, including the start and end points of ring geometries.
-				(If this behavior is undesired, duplicates may be removed using
-				<xref linkend="ST_RemoveRepeatedPoints" />).
+				Returns a MultiPoint containing all the coordinates of a geometry.
+                Duplicate points are preserved,
+				including the start and end points of ring geometries.
+				(If desired, duplicate points can be removed by calling
+				<xref linkend="ST_RemoveRepeatedPoints" /> on the result).
 			</para>
             <para>
@@ -2693,7 +2693,7 @@ FROM ST_GeomFromText('LINESTRING(0 0 0, 1 1 1, 2 2 2)') AS g
             </para>
 			<para>
-				M and Z coordinates will be preserved if present.
+				M and Z coordinates are preserved if present.
 			</para>
 			<para>&curve_support;</para>
Summary of changes:
 doc/reference_accessor.xml | 12 ++++++------
 1 file changed, 6 insertions(+), 6 deletions(-)
hooks/post-receive
