[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-465-gbb68502dc
git at osgeo.org
git at osgeo.org
Wed Feb 2 14:02:10 PST 2022
the project "PostGIS".
via bb68502dccd855b78c46eea6b4c1b02136275afd (commit)
from ef7cf315d1819536dbb374e535a264dd2b25f232 (commit)
revisions in full, below.
commit bb68502dccd855b78c46eea6b4c1b02136275afd
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Feb 2 14:01:48 2022 -0800
Reduce the number of function parameters and recommend use of scale/translate for the st_letters function.
diff --git a/doc/reference_constructor.xml b/doc/reference_constructor.xml
index 5daa9d598..ac561142a 100644
--- a/doc/reference_constructor.xml
+++ b/doc/reference_constructor.xml
@@ -1210,8 +1210,6 @@ FROM admin0 WHERE name = 'Canada'
<funcprototype>
<funcdef>geometry <function>ST_Letters</function></funcdef>
<paramdef><type>text</type> <parameter> letters</parameter></paramdef>
- <paramdef choice="opt"><type>double precision</type> <parameter> text_height=100.0</parameter></paramdef>
- <paramdef choice="opt"><type>geometry</type> <parameter> start_position=POINT(0 0)</parameter></paramdef>
<paramdef choice="opt"><type>json</type> <parameter> font</parameter></paramdef>
</funcprototype>
</funcsynopsis>
@@ -1223,6 +1221,8 @@ FROM admin0 WHERE name = 'Canada'
<para>Uses a built-in font to render out a string as a multipolygon geometry. The default text height is 100.0, the distance from the bottom of a descender to the top of a capital. The default start position places the start of the baseline at the origin. Over-riding the font involves passing in a json map, with a character as the key, and base64 encoded TWKB for the font shape, with the fonts having a height of 1000 units from the bottom of the descenders to the tops of the capitals.
</para>
+ <para>The text is generated at the origin by default, so to reposition and resize the text, first apply the <code>ST_Scale</code> function and then apply the <code>ST_Translate</code> function.
<para>Availability: 3.3.0</para>
</refsection>
@@ -1238,9 +1238,13 @@ FROM admin0 WHERE name = 'Canada'
</mediaobject>
</informalfigure>
</refsection>
+ <refsection>
+ <title>Example: Scaling and moving words</title>
+ <programlisting>SELECT ST_Translate(ST_Scale(ST_Letters('Yo'), 10, 10), 100,100);</programlisting>
+ </refsection>
<refsection>
<title>See Also</title>
- <para><xref linkend="ST_AsTWKB" /></para>
+ <para><xref linkend="ST_AsTWKB" />, <xref linkend="ST_Scale" />, <xref linkend="ST_Translate" /></para>
</refsection>
</refentry>
diff --git a/postgis/postgis_letters.sql b/postgis/postgis_letters.sql
index c8d66f944..da57f9edb 100644
--- a/postgis/postgis_letters.sql
+++ b/postgis/postgis_letters.sql
@@ -1,4 +1,4 @@
-CREATE OR REPLACE FUNCTION ST_Letters(letters text, text_height double precision DEFAULT 100, start_position geometry DEFAULT 'POINT(0 0)', font json DEFAULT NULL)
+CREATE OR REPLACE FUNCTION ST_Letters(letters text, font json DEFAULT NULL)
RETURNS geometry
AS
@@ -9,6 +9,7 @@ DECLARE
prevgeom geometry = NULL;
adjustment float8 = 0.0;
position float8 = 0.0;
+ text_height float8 = 100.0;
width float8;
m_width float8;
spacing float8;
@@ -138,9 +139,9 @@ BEGIN
END LOOP;
-- apply the start point and scaling options
wordgeom := ST_CollectionExtract(ST_Collect(wordarr));
- wordgeom := ST_Translate(ST_Scale(wordgeom,
- text_height/font_default_height, text_height/font_default_height),
- ST_XMin(start_position), ST_YMin(start_position));
+ wordgeom := ST_Scale(wordgeom,
+ text_height/font_default_height,
+ text_height/font_default_height);
return wordgeom;
END;
Summary of changes:
doc/reference_constructor.xml | 10 +++++++---
postgis/postgis_letters.sql | 9 +++++----
2 files changed, 12 insertions(+), 7 deletions(-)
hooks/post-receive
