[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-466-ge57f8deba
Wed Feb 2 14:12:52 PST 2022
the project "PostGIS".
       via  e57f8deba8d999ed66d518e73104994bc8c6499b (commit)
      from  bb68502dccd855b78c46eea6b4c1b02136275afd (commit)
revisions in full, below.
commit e57f8deba8d999ed66d518e73104994bc8c6499b
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Feb 2 14:12:48 2022 -0800
    Close errant para
diff --git a/doc/reference_constructor.xml b/doc/reference_constructor.xml
index ac561142a..95ac3ed17 100644
--- a/doc/reference_constructor.xml
+++ b/doc/reference_constructor.xml
@@ -1221,7 +1221,7 @@ FROM admin0 WHERE name = 'Canada'
             <para>Uses a built-in font to render out a string as a multipolygon geometry. The default text height is 100.0, the distance from the bottom of a descender to the top of a capital. The default start position places the start of the baseline at the origin. Over-riding the font involves passing in a json map, with a character as the key, and base64 encoded TWKB for the font shape, with the fonts having a height of 1000 units from the bottom of the descenders to the tops of the capitals.
             </para>
-            <para>The text is generated at the origin by default, so to reposition and resize the text, first apply the <code>ST_Scale</code> function and then apply the <code>ST_Translate</code> function.
+            <para>The text is generated at the origin by default, so to reposition and resize the text, first apply the <code>ST_Scale</code> function and then apply the <code>ST_Translate</code> function.</para>
             <para>Availability: 3.3.0</para>
         </refsection>
Summary of changes:
 doc/reference_constructor.xml | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
