[postgis-tickets] [PostGIS] #5080: script based upgrade from 2.5.6 fails: ERROR: window function st_clusterkmeans requires an OVER clause
trac at osgeo.org
Thu Feb 3 06:23:20 PST 2022
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.3.0
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by strk):
Enabling warnings in the upgrade script shows that ALTER EXTENSION UPDATE
does enter the block attempting to rewrite the function in SQL but for
some reason that block does not end up raising an exception:
WARNING: Handling deprecated function
st_clusterkmeans_deprecated_by_postgis_302(geometry,integer)
WARNING: SQL: CREATE OR REPLACE FUNCTION
public.st_clusterkmeans_deprecated_by_postgis_302(geom geometry, k
integer)
RETURNS integer
LANGUAGE sql
WINDOW STRICT
AS $$ SELECT st_clusterkmeans($1,$2) $$
If I try the command manually I do get the exception. There must be some
special environment during extension upgrade/creation that prevents the
exception from being thrown.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5080#comment:4>
