[postgis-tickets] [PostGIS] #5080: script based upgrade from 2.5.6 fails: ERROR: window function st_clusterkmeans requires an OVER clause
trac at osgeo.org
Thu Feb 3 06:35:43 PST 2022
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.3.0
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by strk):
When upgraded via EXTENSION mechanism, the wrapper function GETS created
but is non-functioning at runtime:
postgis_reg=# select st_clusterkmeans_deprecated_by_postgis_302(g1, 1)
over () from upgrade_test;
LINE 1: SELECT st_clusterkmeans($1,$2)
QUERY: SELECT st_clusterkmeans($1,$2)
CONTEXT: SQL function "st_clusterkmeans_deprecated_by_postgis_302" during
startup
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5080#comment:5>
