[postgis-tickets] [PostGIS] #5079: concaveHull test fails with current GEOS main branch
trac at osgeo.org
Tue Feb 8 12:01:52 PST 2022
Reporter: strk | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.3.0
Component: postgis | Version: 3.2.x
Resolution: invalid | Keywords:
Changes (by pramsey):
* status: reopened => closed
* resolution: => invalid
Comment:
You are running a test (regress/core/concave_hull) that only should be run
when GEOS < 3.11. So this is not a problem. The harmonized signature you
did works correctly. I added a regress/core/geos311 test that (gently)
exercises concave hull, so both cases (new and old GEOS) are exercised
correctly.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5079#comment:7>
