[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-560-g366d83f79
Thu Feb 17 14:14:42 PST 2022
the project "PostGIS".
       via  366d83f797af12c1b193cdb6bda1ff6bb48f9518 (commit)
      from  137b70304a1def08e2955abc422810e95e6d798e (commit)
revisions in full, below.
commit 366d83f797af12c1b193cdb6bda1ff6bb48f9518
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Feb 17 16:16:00 2022 -0500
    Drop support for PostgreSQL 9.6 and 10
diff --git a/NEWS b/NEWS
index 5a13ae0a7..9b4407b0f 100644
--- a/NEWS
+++ b/NEWS
@@ -2,7 +2,7 @@ PostGIS 3.3.0dev
 2022/MM/DD
  * Breaking changes *
+  - Drop support for PostgreSQL 9.6 and 10 (Regina Obe)
  * Enhancements *
   - postgis_extensions_upgrade() support for upgrades from any PostGIS
diff --git a/configure.ac b/configure.ac
index 1e5bb8337..35b55eb3a 100644
--- a/configure.ac
+++ b/configure.ac
@@ -496,15 +496,12 @@ if test "x$LIBLWGEOM_ONLY" = "xno"; then
   PGSQL_SHAREDIR=`"$PG_CONFIG" --sharedir`
   AC_MSG_RESULT([checking PostgreSQL version... $PGSQL_FULL_VERSION])
-  dnl Ensure that we are using PostgreSQL >= 9.6
-  if test $POSTGIS_PGSQL_VERSION -lt 96; then
-    AC_MSG_ERROR([PostGIS requires PostgreSQL >= 9.6])
+  dnl Ensure that we are using PostgreSQL >= 11
+  if test $POSTGIS_PGSQL_VERSION -lt 110; then
+    AC_MSG_ERROR([PostGIS requires PostgreSQL >= 11])
   fi
-  HAVE_SPGIST=no
-  if test $POSTGIS_PGSQL_VERSION -gt 100; then
-    HAVE_SPGIST=yes
-  fi
+  HAVE_SPGIST=yes
   dnl Note: We don't need the server-side LDFLAGS or CPPFLAGS because we get these from PGXS
diff --git a/doc/postgis.xml b/doc/postgis.xml
index e454e28ff..5399f5819 100644
--- a/doc/postgis.xml
+++ b/doc/postgis.xml
@@ -13,7 +13,7 @@
 <!-- Change these values to update the version numbers referenced within the documentation -->
 <!ENTITY last_proj_release_version "8.2.1">
 <!ENTITY last_geos_release_version "3.10.1">
-<!ENTITY min_postgres_version "9.6">
+<!ENTITY min_postgres_version "11">
 <!ENTITY introduction SYSTEM "introduction.xml">
 <!ENTITY installation SYSTEM "installation.xml">
diff --git a/libpgcommon/lwgeom_pg.c b/libpgcommon/lwgeom_pg.c
index 6243fca78..ce8c05543 100644
--- a/libpgcommon/lwgeom_pg.c
+++ b/libpgcommon/lwgeom_pg.c
@@ -35,9 +35,7 @@
 #include "../postgis_config.h"
-#if POSTGIS_PGSQL_VERSION >= 100
 #include <utils/regproc.h>
-#endif
 #include "liblwgeom.h"
 #include "lwgeom_pg.h"
@@ -535,51 +533,6 @@ postgis_guc_find_option(const char *name)
-#if POSTGIS_PGSQL_VERSION < 100
-Datum
-CallerFInfoFunctionCall1(PGFunction func, FmgrInfo *flinfo, Oid collation, Datum arg1)
-	FunctionCallInfoData fcinfo;
-	Datum		result;
-	InitFunctionCallInfoData(fcinfo, flinfo, 1, collation, NULL, NULL);
-	fcinfo.arg[0] = arg1;
-	fcinfo.argnull[0] = false;
-	result = (*func) (&fcinfo);
-	/* Check for null result, since caller is clearly not expecting one */
-	if (fcinfo.isnull)
-		elog(ERROR, "function %p returned NULL", (void *) func);
-	return result;
-Datum
-CallerFInfoFunctionCall2(PGFunction func, FmgrInfo *flinfo, Oid collation, Datum arg1, Datum arg2)
-	Datum		result;
-	InitFunctionCallInfoData(fcinfo, flinfo, 2, collation, NULL, NULL);
-	fcinfo.arg[1] = arg2;
-	fcinfo.argnull[1] = false;
-	return result;
-#else
 #if POSTGIS_PGSQL_VERSION < 120
 Datum
 CallerFInfoFunctionCall3(PGFunction func, FmgrInfo *flinfo, Oid collation, Datum arg1, Datum arg2, Datum arg3)
@@ -630,5 +583,3 @@ CallerFInfoFunctionCall3(PGFunction func, FmgrInfo *flinfo, Oid collation, Datum
     return result;
 #endif
-#endif
diff --git a/libpgcommon/lwgeom_pg.h b/libpgcommon/lwgeom_pg.h
index 49d73b88e..d14937028 100644
--- a/libpgcommon/lwgeom_pg.h
+++ b/libpgcommon/lwgeom_pg.h
@@ -18,9 +18,7 @@
 #include "postgres.h"
 #include "fmgr.h"
 #include "catalog/namespace.h" /* For TypenameGetTypid */
-#if POSTGIS_PGSQL_VERSION > 100
 #include "catalog/pg_type_d.h" /* For TypenameGetTypid */
-#endif
 #include "utils/geo_decls.h"
 #include "utils/lsyscache.h"
 #include "utils/memutils.h"
diff --git a/postgis/geography.sql.in b/postgis/geography.sql.in
index 4fa9aaa11..5b4e904ab 100644
--- a/postgis/geography.sql.in
+++ b/postgis/geography.sql.in
@@ -296,9 +296,7 @@ CREATE OPERATOR CLASS gist_geography_ops
 	FUNCTION        1        geography_gist_consistent (internal, geography, int4),
 	FUNCTION        2        geography_gist_union (bytea, internal),
 	FUNCTION        3        geography_gist_compress (internal),
-#if POSTGIS_PGSQL_VERSION < 110
 	FUNCTION        4        geography_gist_decompress (internal),
-#endif
 	FUNCTION        5        geography_gist_penalty (internal, internal, internal),
 	FUNCTION        6        geography_gist_picksplit (internal, internal),
 	FUNCTION        7        geography_gist_same (box2d, box2d, internal);
diff --git a/postgis/lwgeom_box3d.c b/postgis/lwgeom_box3d.c
index 28448f19d..8aec40375 100644
--- a/postgis/lwgeom_box3d.c
+++ b/postgis/lwgeom_box3d.c
@@ -597,7 +597,6 @@ Datum BOX3D_construct(PG_FUNCTION_ARGS)
 /** needed for sp-gist support PostgreSQL 11+ **/
  * BOX3D functions
@@ -935,4 +934,3 @@ PGDLLEXPORT Datum BOX3D_distance(PG_FUNCTION_ARGS)
 	BOX3D *box2 = PG_GETARG_BOX3D_P(1);
 	PG_RETURN_FLOAT8(BOX3D_distance_internal(box1, box2));
-#endif
diff --git a/postgis/lwgeom_box3d.h b/postgis/lwgeom_box3d.h
index bcacb533a..80107977e 100644
--- a/postgis/lwgeom_box3d.h
+++ b/postgis/lwgeom_box3d.h
@@ -64,7 +64,6 @@ bool BOX3D_overback_internal(BOX3D *box1, BOX3D *box2);
 double BOX3D_distance_internal(BOX3D *box1, BOX3D *box2);
 Datum BOX3D_contains(PG_FUNCTION_ARGS);
 Datum BOX3D_contained(PG_FUNCTION_ARGS);
 Datum BOX3D_overlaps(PG_FUNCTION_ARGS);
@@ -82,4 +81,3 @@ Datum BOX3D_overfront(PG_FUNCTION_ARGS);
 Datum BOX3D_back(PG_FUNCTION_ARGS);
 Datum BOX3D_overback(PG_FUNCTION_ARGS);
 Datum BOX3D_distance(PG_FUNCTION_ARGS);
-#endif
diff --git a/postgis/mvt.c b/postgis/mvt.c
index f128e6c21..4f5f9e87a 100644
--- a/postgis/mvt.c
+++ b/postgis/mvt.c
@@ -36,11 +36,6 @@
 #include "lwgeom_wagyu.h"
-/* See trac ticket #3867 */
-# define DatumGetJsonbP DatumGetJsonb
-#endif
 #define uthash_fatal(msg) lwerror("uthash: fatal error (out of memory)")
 #define uthash_malloc(sz) palloc(sz)
 #define uthash_free(ptr,sz) pfree(ptr)
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 786473078..86ba08bca 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -844,9 +844,7 @@ CREATE OPERATOR CLASS gist_geometry_ops_2d
 	FUNCTION        1        geometry_gist_consistent_2d (internal, geometry, int4),
 	FUNCTION        2        geometry_gist_union_2d (bytea, internal),
 	FUNCTION        3        geometry_gist_compress_2d (internal),
 	FUNCTION        4        geometry_gist_decompress_2d (internal),
-#endif
 	FUNCTION        5        geometry_gist_penalty_2d (internal, internal, internal),
 	FUNCTION        6        geometry_gist_picksplit_2d (internal, internal),
 	FUNCTION        7        geometry_gist_same_2d (geom1 geometry, geom2 geometry, internal);
@@ -1031,9 +1029,8 @@ CREATE OPERATOR CLASS gist_geometry_ops_nd
 	FUNCTION        1        geometry_gist_consistent_nd (internal, geometry, int4),
 	FUNCTION        2        geometry_gist_union_nd (bytea, internal),
 	FUNCTION        3        geometry_gist_compress_nd (internal),
+	-- Changed: 3.3.0
 	FUNCTION        4        geometry_gist_decompress_nd (internal),
-#endif
 	FUNCTION        5        geometry_gist_penalty_nd (internal, internal, internal),
 	FUNCTION        6        geometry_gist_picksplit_nd (internal, internal),
 	FUNCTION        7        geometry_gist_same_nd (geometry, geometry, internal);
@@ -4966,10 +4963,8 @@ CREATE AGGREGATE ST_AsMVT(anyelement)
 	serialfunc = pgis_asmvt_serialfn,
 	deserialfunc = pgis_asmvt_deserialfn,
 	combinefunc = pgis_asmvt_combinefn,
-	finalfunc = pgis_asmvt_finalfn
-#if POSTGIS_PGSQL_VERSION >= 110
-	,finalfunc_modify = read_write
-#endif
+	finalfunc = pgis_asmvt_finalfn,
+	finalfunc_modify = read_write
 -- Availability: 2.4.0
@@ -4983,12 +4978,11 @@ CREATE AGGREGATE ST_AsMVT(anyelement, text)
-#endif
+-- Changed: 3.3.0
 -- Changed: 3.2.0
 CREATE AGGREGATE ST_AsMVT(anyelement, text, int4)
@@ -4998,13 +4992,12 @@ CREATE AGGREGATE ST_AsMVT(anyelement, text, int4)
-#endif
+-- Changed: 3.3.0
 -- Changed: 3.2.0
 CREATE AGGREGATE ST_AsMVT(anyelement, text, int4, text)
@@ -5014,13 +5007,12 @@ CREATE AGGREGATE ST_AsMVT(anyelement, text, int4, text)
-#endif
 -- Availability: 3.0.0
+-- Changed: 3.3.0
 -- Changed: 3.2.0
 CREATE AGGREGATE ST_AsMVT(anyelement, text, int4, text, text)
@@ -5030,10 +5022,8 @@ CREATE AGGREGATE ST_AsMVT(anyelement, text, int4, text, text)
-#endif
@@ -5127,27 +5117,25 @@ CREATE OR REPLACE FUNCTION pgis_asflatgeobuf_finalfn(internal)
 	_COST_MEDIUM;
 -- Availability: 3.2.0
+-- Changed: 3.3.0
 CREATE AGGREGATE ST_AsFlatGeobuf(anyelement)
 	sfunc = pgis_asflatgeobuf_transfn,
 	stype = internal,
 	parallel = safe,
-	finalfunc = pgis_asflatgeobuf_finalfn
-#endif
+	finalfunc = pgis_asflatgeobuf_finalfn,
+-- Changed: 3.3.0
 CREATE AGGREGATE ST_AsFlatGeobuf(anyelement, bool)
 	stype = internal,
 	parallel = safe,
-#endif
diff --git a/postgis/postgis_spgist.sql.in b/postgis/postgis_spgist.sql.in
index 706650ef1..060f54744 100644
--- a/postgis/postgis_spgist.sql.in
+++ b/postgis/postgis_spgist.sql.in
@@ -1,5 +1,4 @@
 #include "sqldefines.h"
 -- SP-GiST 2D Support Functions
@@ -265,5 +264,3 @@ CREATE OPERATOR CLASS spgist_geography_ops_nd
 	FUNCTION		4		geography_spgist_inner_consistent_nd(internal, internal),
 	FUNCTION		5		geography_spgist_leaf_consistent_nd(internal, internal),
 	FUNCTION		6		geography_spgist_compress_nd(internal);
-#endif
Summary of changes:
 NEWS                          |  2 +-
 configure.ac                  | 11 ++++------
 doc/postgis.xml               |  2 +-
 libpgcommon/lwgeom_pg.c       | 49 -------------------------------------------
 libpgcommon/lwgeom_pg.h       |  2 --
 postgis/geography.sql.in      |  2 --
 postgis/lwgeom_box3d.c        |  2 --
 postgis/lwgeom_box3d.h        |  2 --
 postgis/mvt.c                 |  5 -----
 postgis/postgis.sql.in        | 48 ++++++++++++++++--------------------------
 postgis/postgis_spgist.sql.in |  3 ---
 11 files changed, 24 insertions(+), 104 deletions(-)
hooks/post-receive
