[postgis-tickets] [PostGIS] #5100: PostgreSQL 15 failure
PostGIS trac at osgeo.org
Thu Feb 17 14:20:53 PST 2022
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.3.0
Component:  postgis  |    Version:  3.2.x
 Keywords:           |
 I think this is a PostgreSQL 15 new issue.
 Debbie is complaining when compiling against PG 15
 17:17:47 gserialized_typmod.c: In function ‘gserialized_typmod_in’:
 17:17:47 gserialized_typmod.c:275:19: warning: implicit declaration of
 function ‘pg_atoi’; did you mean ‘pg_ltoa’? [-Wimplicit-function-
 declaration]
 17:17:47   275 |    int32_t srid =
 pg_atoi(DatumGetCString(elem_values[i]), sizeof(int32), '\0');
 17:17:47       |                   ^~~~~~~
 17:17:47       |                   pg_ltoa
 17:02:23 psql:/var/lib/jenkins/workspace/postgis/branches/3.3/regress/00
 -regress-install/share/contrib/postgis/postgis.sql:138: ERROR:  could not
 load library "/var/lib/jenkins/workspace/postgis/branches/3.3/regress/00
 -regress-install/lib/postgis-3.so":
 /var/lib/jenkins/workspace/postgis/branches/3.3/regress/00-regress-
 install/lib/postgis-3.so: undefined symbol: pg_atoi
 17:02:23
 17:02:23  failed (Error encountered loading
 install/share/contrib/postgis/postgis_comments.sql:
 /var/lib/jenkins/workspace/postgis/tmp/3_3_pg15w64/regress_log)
 17:02:23
 17:02:23 NOTICE:  schema "public" already exists, skipping
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5100>
